91 22re stalling around 1500 rpm
Old Nov 2, 2009 | 06:14 PM
Blitzkrieg3002's Avatar
i have a 1991 toyota pickup extra cab with a 4 cyl. 22re engine, i recently dropped in a new long block and swapped a lot of engine parts, checked vacccum hoses to the best of my ability with a few diagrams, and my check engine light is not on after connecting all of the sensors and such, but i just noticed tonight driving home at a stop sign when sitting in neutral or with my foot on the clutch if i bring it up from an idol to about 1500 anywhere between 1100-2000 rpm it stalls out back down to about 900 rpm then back up then back down like it's dying out/stalling out, if i push the gas a bit harder it seems to do nothing until i yet again push it in even harder and it picks up to about 2100/2000 rpms, its very strange like it seems the low end power is very weak as well, i do hear a ticking noise and i adjusted the valves recently as well and the tick has not gone away, i'm not to sure if anyone has any advice please let me know thank you
Old Nov 2, 2009 | 11:01 PM
olharleyman's Avatar
check your afm claps for air leaks my 3.0 did tha and that was what the problem was may be your issue not sure just a idea.
Old Nov 2, 2009 | 11:25 PM
turboboost's Avatar
Adjust your idle setting. This has been covered many times before.
Old Nov 3, 2009 | 06:56 AM
if possible could one of you provide me a link that would show the proper idle adjusment process, i've attempted to do it following my chiltons book but i may have done something wrong or not too sure, i did adjust the sensor the screw on the top facing vertical to adjust the idle as well as moving the position of the throttle cable itself with the adjusting nuts on each side of the clamp to position the cable. any idea's on the knocking/ticking sound i'm exhausted on what it could be, i've been trying to find out for a few months now as i said i adjusted the valves and i actually adjusted them about one to two thousands of an inch tighter than it said in the book incase of wear/break in on the new engine. maybe thats just how the yota sounds normally not too sure but i can hear a tick that speeds up and slows with the engine rpm that doesn't sound quite normal
Old Nov 3, 2009 | 08:24 AM
Junkers88's Avatar
Had a hard time understanding what you mean so this question may not really help.
From what you wrote if you push on the gas pedal while sitting at a stop light the truck will rev up to about 1500rpm and then drop back down to 900rpm, correct? First I want to know why you are pushing the gas pedal at a stop light with the clutch in or the transmission in nuetral but we'll leave that for later.
If the rpm are climbing by without you pushing the gas pedal and then dropping back to 900 over and over then what you need to do is adjust your idle back down to 900. The engine is idling too high.
Old Nov 3, 2009 | 10:16 AM
Let me rephrase it a bit to clarify, if i'm sitting at a stop with my car in neutral/clutch pushed in it idols fine, maybe a bit high usually around 1,000 rpms somewhat varies it seems between 900 - 1100 rpm. now, there is no reason for me to be barely stepping on the gas to raise up my rpms at a stop i understand but, i noticed it i guess by acidentally barely and i mean if i barely push on the gas, my rpm does not change at all, if i barely push a little bit harder and im talking very slightly the engine tries to rev up and stalls out like its dying and starts bouncing back between about 1500 - 600 rpms it like revs up a bit and dies out revs up and dies out never actually dies just bounces if i let off it goes back to the idol if i press a bit harder it jumps straight from the idol (around 900 - 1100) or wherever its bouncing at that time straight to about 2000 - 2200 rpms this is all at a stop, now i understand this doesn't directly affect me as i drive the car daily and it drives around fine and i can accellerate from a stop even with this issue without noticing it, but still it doesn't seem right for this to be happening its almost seems as tho this may be part of the reason for my next to none low end power (like the 22re gives any) but my yota feels like it has like next to no low end, the timing may be to far advanced i'm going to retard it a bit because going up a hill if i full throttle i hear some noises i guess its pinging but sounds like pieces of metal being shaken around in a case sort of sound. also engine ticks fairly loudly even after the valve/rocker adjusment made no difference. i'm going to double check the vaccum lines and make sure i don't have one crossed up somewhere after the engine swap even though i already have done that 3 or so times, i still havn't been able to find a direct diagram that matches my engine. 91 22re toyota pickup.
Old Nov 3, 2009 | 10:27 AM
Junkers88's Avatar
Ah. When all this is happening are you also holding the brake pedal down?
Old Nov 3, 2009 | 10:43 AM
hmm i think so i'll have to check again and see if it does it regardless of the brake being pushed in or not
Old Nov 3, 2009 | 11:31 AM
Junkers88's Avatar
If you are holding the brake then the surging in idle caused by you pushing the gas pedal is coming from the ECU. When you are on the brake the ECU believes that you are at a stop and it wants the engine to idle (900rpm). So when you give it some gas while on the brake the ECU is going to cut the fuel and try to get back to idle. If you continue to hold the brake and give it gas the idle will bounce from about 1500rpm (this is where the ECU cuts the fuel) back down to idle (900rpm).
I hope that makes some sense.
Old Nov 3, 2009 | 11:50 AM
i see, yes it makes sense to me, so if i do discover tonight when i drive home that it only seems to be happening when my foot is on the brake and not when my foot is off of the brake then this is normal and i shouldn't worry, as i wouldn't be accellerating and braking at the same time anyways just stumbelled across this last night and seemed strange but i will check it out tonight and post an update
Old Nov 3, 2009 | 11:51 AM
Junkers88's Avatar
If it only does it when your foot is on the brake then don't worry.
Old Nov 4, 2009 | 12:01 PM
you are right, it seems it only does this when my foot is on the brake and when i let up on the brake in the midst of it happening it stops so yes i'd assume that it is normal. thanks so much for the info haha i thought i had stumbled onto something strange. but as far as the engine tick goes i'm going to try and adjust my valves again i guess the sound is definitely coming from the valve cover area and seems a lot louder than it seems it should be. not too sure maybe the yota just ticks really loud
Sleaker
Aug 26, 2020 06:03 AM
Dakotaneu
Jul 27, 2015 12:03 AM
ddg71
Jul 24, 2015 01:24 PM
ty1er
Jul 19, 2015 06:42 PM
Jnkml
Jul 6, 2015 01:20 PM
