90s toyota Elocker wiring install
Old Apr 4, 2025 | 08:56 PM
Kinghades_pro's Avatar
Hello everyone im pretty new to all this but i have a 94 single cab 22re Toyota pickup that i put an elocker in from what i think was a 2001-2004 tacoma, and i would like to share how the wiring went and hopefully it will help others
I will be listing 2 ways to wire it up depending on what you are wanting
nice looking and Quick and Dirty
Parts that i used
16ft of 6wire trailer wire
6 pin plug water proof requires 7 but both grounds can just be connected together (i used 8 pin before i found this out)
DPDT Relay 8pin could probably find a better one but heres mine
Amazon Amazon
Toyota Elocker switch
Using the old wiring cut the not needed end off and add your plug and color match the wiring i did
Making Wiring Harness
Green/Black = black
Green = Green
Green/Red = Red
Green/Yellow = Yellow
Blue/Yellow = Brown this is for the sensor it can be used for an indicator light
2 White/Black can be combined
Relay
5 and 4 power
1 black
8 yellow
12 red
9 green
White Ground
Brown to the ground pin of light if your adding it
Last two pins are ground and switch
Toyota Switch
Now the stock Toyota Switch only came with two wires
The black and green
There is a light in the switch that has no connection if you want to uses the light you can cut and unpin the clock wiring and use the pins and wires
I added Blue, Gray, and Purple
Blue and Gray are for the light inside the switch
Purple is another power out source if you want another exterior light when it is pressed in
Blue and Black can be combined
Gray is Ground
things get a bit fussy for me cuse it was the las thing i did, but i believe black and blue are power and green is power out (could be the other way)
Quick and Dirty way
Will need 5 amp fuse, same wiring, and plugs and an (on)-off-(on) switch
honestly the picture does wonders
white to ground
brown to ground side of external light
[img alt="this is the plug that plugs in to the Truck i cut it off and used the other side to the Elocker motor
"]https://cimg9.ibsrv.net/gimg/www.yotatech.com-vbulletin/1500x2000/img_e2412_1__1070b3898c3c8587c85969f34249ae287fc96 109.jpg[/img]
[img alt="(on)-off-(on) switch no relay required just 5amp fuse
"]https://cimg0.ibsrv.net/gimg/www.yotatech.com-vbulletin/2000x1504/img_2411_1__24cf4d76be504a00be72005e7f06633954ef54 37.jpg[/img]
stock Toyota Tacoma switch, needed with DPDT Relay and 5amp fuse (i used 10amp)
Old Apr 4, 2025 | 08:59 PM
Old Apr 10, 2025 | 01:51 AM
ColtonZeke's Avatar
Thanks for sharing, it's super helpful for anyone doing this mod!
Icyinjax
May 1, 2020 03:56 PM
emmantik
Aug 17, 2013 02:36 AM
stanz
Feb 5, 2012 09:54 PM
snoozer
Mar 27, 2011 08:59 AM
