89 sr5 ext cab seat swap
tried using the "search" first and didnt really get the answer i was looking for. so i was wondering what would be the easiest swap to make. i have a 60/40 bench now, but would like buckets. even if it is non toyota, what worked for you guys. thanks brian
Well, I would recommend finding some buckets from a 3rd generation pickup like yours. That's what I did and it worked pretty well. For each seat, three of the four bolt holes lined up perfectly. And I just left it like that. If you wanted to add the fourth hole it would be easy to do. But I would stick to Toyota seats for a relatively easy application. Also, the stock Toyota center console can be modded to fit in the gap between the seats once finished.
A lot of guys have done a number of different seats from various makes and models but they involve a lot more fabrication than I would want to do just for a pair of seats. To each his own. . . . . .
Good luck, and post some pictures if you find a set that you put in there.
thanks sam, i havent been able to find any seats that would drop in so to speak. i have seats out of camrys accords neons and a few small car seats that are fairly reasonably priced and in good shape. i didnt know how difficult a mod would be on a seat frame to attach to a slider. thanks again
i am replacing mine for a reason.... its shot! its light blue/gray ish. but driver side is all dry rotted, and falling apart. i use my truck to do my run arounding in, and i do alot of hunting out of it. just thought buckets would be a better choice, and access into back seat would be much easier.
4Runner buckets are pretty much plug n play. I ran a pair I got from a junkyard for a while, but I jumped on Toyota MR2 buckets when I got the chance. Brackets take a little bit of work, but well worth it.
I didn't drill holes in my floor, instead I built a little bracket that allowed me to use the stock holes.
Sorry, blanking on the thread I posted my seat swap in at the moment...
This is a write-up of how he did it.
https://www.yotatech.com/wiki/index...._Toyota_Pickup
Johntom240
7
Jul 13, 2015 12:18 AM
icentropy
Jul 9, 2015 02:12 PM
Steezy96yota
Jul 6, 2015 10:00 AM
