89 Oil Sending Unit
Old Jul 30, 2013 | 03:42 AM
bbrock1415's Avatar
Question 89 Oil Sending Unit
I have a 1989 4wd truck and recently the oil pressure gauge quit working. I found that the wire was broke loose but not from the oil sending unit. I hooked the wire back up and the gauge was reading a really high pressure and when I went down the road it went all the way over to high pressure. Now when I crank the truck the gauge is reading nothing again. Do y'all have any suggestions as why might can fix this problem.
Old Jul 30, 2013 | 12:21 PM
stinkfoot's Avatar
Test the pressure sending unit first. Verify that it's working, then check your wiring and the gauge. Or, you can work the opposite direction back down to the sending unit. Just grab a multimeter and work sequentially through it.
My gauge always reads low, even though the pressure is good.
Old Jul 31, 2013 | 03:28 PM
bbrock1415's Avatar
I checked my wiring and it seems to be hooked up right. I am thinking I may need to buy a new unit
Old Aug 1, 2013 | 12:47 PM
stinkfoot's Avatar
Is there a single lead coming off of the pressure sending unit? or is it several wires?
Old Aug 1, 2013 | 03:09 PM
stinkfoot's Avatar
Anyway, with key on engine off, pull the cable off the sending unit. Check your gauge. It should peg. Then, if you ground it, it should read zero. (There's a chance I may be thinking backwards on this one)
If the gauge responds like that, your wiring and gauge are good, leaving only the pressure sending unit as the faulty component. If your gauge doesn't respond, you'll have to start looking elsewhere.
Let me know how it works out.
Old Aug 2, 2013 | 04:39 AM
bbrock1415's Avatar
There is only one wire that runs from the oil sending unit. Update gauge still not working and when I turn the switch on I am hearing like a clicking noise which sounds like it is coming out of the shifter. I am not sure if this has anything to do with gauge or not. Any advice
Old Aug 3, 2013 | 12:58 PM
stinkfoot's Avatar
More details needed. Just work things one at a time.
Did you get the wiring to the gauge tested? Once you've got that, give details on the clicking sound. Engine running or off? Are you talking the key switch? Or a different switch? What sort of clicking noise?
Old Aug 5, 2013 | 03:45 AM
bbrock1415's Avatar
The wire has power. The clicking sound happens when I press the brakes and it sounds like it is coming from the gear changer. It does when the key is on but engine off and it also does it when key is on and engine is on. The noise sounds like a pen tapping on a table. I started hearing the clicking noise a couple days before then the gauge stopped working. I think I will just end up taking it to someone who understands the wiring. I am not real familiar with all them wires.
Doug4320
Mar 24, 2018 10:11 PM
gary4runner
Sep 24, 2015 12:53 AM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
