'89 4Runner - Why the Nasty Engine Noise? See video...
Old Apr 26, 2011 | 07:44 PM
dendiggity's Avatar
Yota-tech'ers,
Did the head gasket and welded the hole in the timing chain cover that got eaten away by a timing chain with broken guides.
Belts are all disconnected.
22 RE 2.4
Makes nasty noise that sounds mechanical, not vacuum related (could be both possibly...)
Novice mechanic looking for help!
Thanks,
Denis
http://www.youtube.com/watch?v=05momANGxYs
Old Apr 26, 2011 | 08:16 PM
skoti89's Avatar
did you grind your welds down smooth?
Old Apr 26, 2011 | 08:18 PM
skoti89's Avatar
and if your belts are disconnected, wouldn't the pulley( or whatever its called) be spinning freely?
Old Apr 26, 2011 | 11:20 PM
dendiggity's Avatar
Smooth as a baby's bottom, and yes, the crankshaft pulley is spinning freely...made the same noise with the belts on.
Old Apr 27, 2011 | 04:14 PM
skoti89's Avatar
Im at a loss then...
Old Apr 28, 2011 | 06:47 AM
vonroll's Avatar
to me it almost sounds like plastic. Could the fan be rubbing on the radiator? Was it in any sort of front end collision? When you let off, the sound decreases slower than the engine sound making me also think fan clutch and fan. worth a look.
Old May 1, 2011 | 10:55 AM
drmix's Avatar
Definitely sounds like somethings rubbing. Id let it run and try and pin point where the sounds coming from
Old May 1, 2011 | 11:27 AM
xxxtreme22r's Avatar
to me that sounds like a gear mesh noise. One thing comes to mind is the oil pump drive spline in backwards. or maybe the oil pump gears themselves not lining up right.
Did you get oil pressure yet?
Old May 1, 2011 | 01:00 PM
toyota4x4907's Avatar
The crankshaft pulley is spinning freely as in its spinning freely by hand? or you mean no belts attached?
Is it not even starting?
Checked the dizzy? made sure its timed correctly?
It does kind of sound like gears whining...
Old May 10, 2011 | 02:10 AM
dendiggity's Avatar
Duh...
Didn't put the throttle body to intake manifold together correctly - attached a ground over the stud before putting the EFI unit, NOT after, thus creating a fissure for air to get through.
Thanks for the replies...
arlindsay1992
Jan 23, 2024 01:34 PM
voiddweller
19
May 2, 2016 09:10 PM
Outsane
Jul 15, 2015 05:01 AM
camdenbuck
Jul 7, 2015 07:33 AM
puddlepirate
Jun 30, 2015 05:08 PM
