89 3.0 is puking coolant
Old Oct 7, 2010 | 08:01 PM
sportbiker929's Avatar
Haven't really looked yet, but it is spewing coolant and steaming from under the hood. Should I assume that my head gaskets are blown? Or could it be just the pump?
Thanks,
Mitch
Old Oct 7, 2010 | 08:09 PM
xxxtreme22r's Avatar
it's a 3.0 that's perfectly normal.
haha J/K never assume anything, pop that hood open and stick your head in there to see what's going on.
Old Oct 15, 2010 | 10:57 AM
Oh Boy! So I started it and ran it hard around the block several times and it started puking. Looks like the coolant is coming right rear of the head and on top under the plenum on the left side.
so what do you guys think?
should i do the head gaskets or buy a donor LS400?
hmmmm.
Old Oct 15, 2010 | 11:25 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
hmmmm.
If you can afford the donor and can do the swap, this sounds like a great time to do it!
Old Oct 16, 2010 | 08:01 PM
BC Rider's Avatar
[QUOTE=sportbiker929;51572837]Oh Boy! So I started it and ran it hard around the block several times and it started puking. Looks like the coolant is coming right rear of the head and on top under the plenum on the left side.
hmmmm.[/QUOTE
check underneath the plenum at the back. i had a small hose there go and it puked collant all over the back on the engine and the exhaust manifolds. lots of steam.
iirc....there are several hoses there that come from barbs on the engine and connect to other lines.
there is a diagram here. http://personal.utulsa.edu/~nathan-b...05descript.pdf
i had one of those hoses back there go. first just a bit and then a big cloud in the space of about 2 weeks.
Old Mar 8, 2011 | 09:30 PM
[quote=BC Rider;51573880]
hmmmm.[/QUOTE
there is a diagram here. http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/105descript.pdf
turns out, thats all it was. a split rubber hose connected @ the throttle body. sure glad i didn't tear it apart yet. thanks for the tip.
Old Mar 9, 2011 | 05:06 AM
Team420's Avatar
Good Deal!! I'm happy to see a thread like this that dosent result in blown h/g's for once !!
Old Mar 9, 2011 | 05:52 AM
Yeah, me too!
SubiKing
Aug 21, 2021 03:57 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
pyramid
Jul 29, 2015 06:53 AM
itzmywife's
Jul 25, 2015 04:55 PM
