89 22re 4runner cut tps wires need matching
Old Mar 31, 2018 | 03:30 PM
Justinkle's Avatar
I recently started working on my 89 4runner 22re straight axle swap and I forgot that I had cut off the TPS plug to use on another vehicle which I no longer have.
The problem I’m having now is matching which color wire to which pin in the tps sensor.
my colors are blue black white brown. If anyone has the same color wires going to the TPS it would be awesome if you could let me know which pin takes what color.
Old Apr 1, 2018 | 03:34 AM
wyoming9's Avatar
Red face
I don`t have the 1989 EWD and Looking at the ones I have your Colors don`t come close at all
Maybe some one has what you need
Old Apr 1, 2018 | 11:00 AM
Bad Karma's Avatar
Here's a reference pic I took of my TPS connector, from an '87 4Runner.
Old Apr 1, 2018 | 02:59 PM
scope103's Avatar
Don't forget that wires have a body and stripe color, e.g. W-R is white with red stripes.
Old Apr 1, 2018 | 05:00 PM
Justinkle's Avatar
Much appreciated Bad Karma! That’s what I needed
Old Apr 1, 2018 | 11:51 PM
wyoming9's Avatar
Red face
THe Op`s colors did not come close to the 89 colors so who knows what year engine is in his vehicle
Old Apr 3, 2018 | 09:29 AM
Justinkle's Avatar
Ended up tracing the wires from the EC you and found my coloring that photo help a lot though. Ended up having starting troubles after that my car would start run for a few seconds and shut off I replace the PCV valve mass airflow sensor air filter and fuel filter. Started up and it ran perfect
my truck is a 88/89 split year so a lot of the parts are different or the same
just curious does anyone have OEM height front leaf springs off an 84 or 85. If so I would trade you straight up for my trail gear 3 inch lift Springs brand new... I Really just want a low drivable ride height really just want a low drivable ride height for my SAS
Old Apr 3, 2018 | 09:33 AM
Justinkle's Avatar
I already bought the low range chevy swap kit and the chevy springs I’m getting are only 2+1 off a 05 chevy 1500.
any other suggestions for lowering the front?
i as well planning on running 33’s or 35’s once I have money to re-gear
It only has 117k original miles btw😁
Oneturboneeded
Jul 7, 2013 03:40 AM
tj884Rdlx
20
Jul 13, 2011 02:07 PM
Hardstripe
Jun 17, 2009 12:56 PM
PutzRunner
9
Aug 7, 2004 05:18 PM
