88 v6 SR5 Toyota pickup starting problem
Old Feb 11, 2014 | 01:59 PM
yoterboy1989's Avatar
Hello guys. im looking for some help...i have a 88 Toyota SR5 pickup 3.0 v6.... i am having a starting issue when its hot after its been running for awhile.....Iv replace fuel pump, fuel filter, injectors, fuel injector damper on fuel rail, new batter, and new cold start injector(on side of intake).....The shop told me that it was the injectors but i just put those in and its still having the issue.... if i hit it with starter fluid... and give it throttle it will run until i shut it off(unless i hit it with starter fluid again).... its cranking so cant be starter, when it runs it runs like a champ... so cant be timing.... i really cant thin of anything else.... it has a new brain(computer) ...im just stumped please help or tell me if you have experienced this
Old Feb 18, 2014 | 06:27 PM
NickB47's Avatar
I had a similar issue at one point, try checking the VAF unit. There are instructions on how to do the check with a voltmeter in the FSM: http://personal.utulsa.edu/~nathan-b...33volumeai.pdf
Old Feb 19, 2014 | 07:54 AM
four50rdr's Avatar
Sounds similar to the problem I'm having. 1993 Toyota Pickup SR5 V6 3.0 202,000 mi. Starts and runs fine when cold, but once it gets up to normal temp, it won't start unless you give it a little throttle, it basically seems like it is flooded out, but will run fine again once started and burns that extra fuel.
When I got to looking around, I noticed my intake hose was cracked, so I replaced that. It crumbled into about 10 pieces getting it off, problem still exists, although I never suspected that to be the problem.
From there I'm thinking its my cold start injector not disengaging??
Old Feb 19, 2014 | 08:05 AM
MaK92-4RnR's Avatar
How does it start when its cold? Rough? My 88 is doing the same, and its my IACV ( idle air control valve ) going out. its extremely random and only happens sometimes
Old Feb 19, 2014 | 08:32 AM
four50rdr's Avatar
I started mine up this morning, it was a little rough at first (for about the first 15 seconds or so) and then ran fine. However once it got up to normal temp, it was still running at about 1700 rpms until I popped the throttle, then it dropped back down to the normal (about 700 rpms).
Once it was to normal temp, I tried to restart it and it wouldn't start unless you worked the throttle a little. After it did start again, it ran rough for about 15 seconds again and then ran fine at about 700 rpms.
Old Feb 19, 2014 | 09:02 AM
mbomberz1's Avatar
This seems like a common trend on these 3.0s. My 88 does something similar to this. I imagine its just the beginning of how bad some of yours are. Starts up no problem when the engine is cold, if i drive it up to to temp and stop for a few minutes then restart, it idles real low. Never has actually died on me yet but it drops to 400-500 rpm and i usually give it some gas. By the time i take off and get to my first stop light, its back to purring at 700rpm like nothing has happened. Would love to hear any sure fire solutions that might come up in this thread !
Old Feb 19, 2014 | 09:07 AM
four50rdr's Avatar
Im going to check the IACV, the cold start injector, and the time switch.
I had my VAF replaced about 5 years ago, but if my intake hose was cracked, could it have got some back pressure to it causing it to malfunction?
6th Gear
19
Dec 10, 2019 07:31 AM
Crazychris1871
Jun 27, 2016 10:38 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
