88 3.o engine stalls when air intake removed is this normal?
A fuel injected engine needs to know the air flow in order to run. That's the Vane Air Flow meter on top of the air filter. If by "air intake removed" you have disconnected the induction plumbing between the throttle body and air filter box, then yes, it SHOULD stall.
OK great thanks for a much I can cross that off the list now
FRANCOARMANI
Oct 9, 2015 01:27 PM
