88 3.0 will not start - Code 14
Old Dec 3, 2007 | 09:48 AM
DeathCougar's Avatar
I double-checked interchange. Looks like 88 V6 truck, and 88-89 V6 4runner will work. You cannot use 89+ Truck, or 90+ 4runner.
Old Dec 3, 2007 | 09:55 AM
thook's Avatar
Is it because there's a difference in the ignition system itself (apparent by number of terminals) or because the plug styles are different?
Old Dec 3, 2007 | 11:10 AM
Green93's Avatar
Originally Posted by thook
Is the CEL atleast coming on when you turn the key to ignition?
No...I don't get a code for faulty coil. But it doesn't test as it should in the FSM.
Old Dec 3, 2007 | 12:14 PM
881stGenRunner's Avatar
a completely different plug style.
  #25
yes and yes.
Both the coil and the ignitor use different plugs, different coil styles, etc etc.
Old Dec 3, 2007 | 01:48 PM
  #26
thook's Avatar
I'm not asking if the CEL is flashing a code. I'm asking if it lights up AT ALL solidly....no flashing....when you turn the key on. Or, does it even come on if you were to jump the diagnostic terminals?
Old Dec 3, 2007 | 01:50 PM
  #27
thook's Avatar
yes and yes.
Oh...because sometimes the parts are the same yet the plugs are different and can therefore just be spliced in. Oh well....worth asking. Thanks.
Old Jan 11, 2014 | 03:21 PM
  #28
toyotaoneton's Avatar
I am having the same problem with my 90 one ton. $350 later, I replaced the igniter and it worked. After letting it run a bit, I shut it off. Did this a handful of times. Guess what. The newer igniter is now bad. What causes them to go bad? Not sure I can afford many more $350 parts (used) for this truck.
Thanks,
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
