88 22re injectors wont work
Old May 13, 2012 | 07:49 PM
bigbadtoy's Avatar
ok i have 88 pickup 4x4 long story short got it from buddy who had problems with it dieing once it warmed up after doing a engine swap(motor threw a rod) it sat about 2yrs prior to me getting it. so i swapped body on my 85 frame went through motor put it back in changed distributor cuz of his previous problems thought it was bad pickup coil. well now it jus runs off cold start injector n dies within couple seconds. Injectors get ignition on pwr. So i went though harness checked for bad injector splices all are good. checked ground splice thats all good. injector resistor was bad replaced with a good one still does samething. next my dad and i started checkin continuity on the wires back to ecu found all pin outs from all data everything check ok. only thing we are puzzled on is the 2 wires coming out of ignitor, the black with red stripe goes to ecu but we get no continuity on it that to me seems to be wire that tell ecu to fire injector. my question is where do those ignitor wires run? from what i can tell they go to outside drivers inner fender and in to cab. so i dunno if ecu is bad or ignitor, this thing just has us both stumped and my father is actually really good with wiring so im askin for your guys help.
Old May 13, 2012 | 07:53 PM
bigbadtoy's Avatar
also forgot to mention ecu was badly corroded took apart cleaned it up a bit everything looked ok. cleaned up connections by it. window seal leaks a bit wonder if it didnt get like water damage. what are your thoughts?
Old May 13, 2012 | 09:29 PM
bobbybouche's Avatar
If those injectors sat for 2 years there's a good chance they're gummed up.
Old May 14, 2012 | 03:06 AM
skypilot's Avatar
Are the years correct?
88 was a year for low impedance injectors. Could you have the later high impedance injectors????
If you double resistance it will definately make it run like crap.
Corroded ECU can be bad, and cause weird problems.
Old May 14, 2012 | 03:33 AM
bigbadtoy's Avatar
I will pull fuel rail tonite an check them injectors. Yeah they are the low impedance injectors correct for the year. I sold him the motor years ago it was 91 he swapped his 88 upper n lower intake over to it
Old May 15, 2012 | 03:38 AM
bigbadtoy's Avatar
Injectors checked good fuel rail to my surprise didnt have no crap in it.
Tonite im off to pick n pull need to find an ecu amd ignitor.
Only thing i believe it could be all wiring and everything checks out good.
Old May 15, 2012 | 11:42 PM
tecate3matt's Avatar
Bust out the test light dude
Old May 16, 2012 | 04:45 PM
Cbertram914's Avatar
Wow ok thats just about the same problem were having with our 88re ours is a 4 runner tho. Very aggravating. If we get ours figured out. I'll sure share the info.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Suprarossa
Jul 6, 2015 05:21 AM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
