'87 Turbo Restoration and Build
Old Aug 1, 2018 | 08:29 AM
  #161
SomedayJ's Avatar
Nice!
Old Aug 1, 2018 | 08:35 AM
  #162
old87yota's Avatar
Originally Posted by jakey poo
Looks like everything is labeled very well! Life size Lego set!
^^ Yes!
You are doing things right. Keeping yourself organized takes out the frustration of "where do these bolts go".
Just working on things a bag or two at a time will make the bags of parts less scary.
The picture would be much scarier if all of those parts were just rolling around in a box somewhere, unlabeled!
Good luck!
Old Aug 1, 2018 | 08:36 AM
  #163
Charles4x4's Avatar
Yes, if only there was an easier way!
Old Aug 1, 2018 | 08:38 AM
  #164
Charles4x4's Avatar
Headlight swap to H4 7” IPF and Amazon LEDs was almost too easy! Man they are bright!
Old Aug 1, 2018 | 09:34 AM
  #165
Charles4x4's Avatar
Front End Done!
Old Aug 1, 2018 | 09:35 AM
  #166
Melrose 4r's Avatar
5 Year Member
Looking great!
How's your camber after the ball joint spacer install?
I had to bring mine in quite a bit.
You are progressing so quickly. It's fun to watch. I've fallen behind on mine!
Old Aug 1, 2018 | 10:00 AM
  #167
old87yota's Avatar
Originally Posted by Charles4x4
Front End Done!
Wow!
You put the front end back together fast.
Old Aug 1, 2018 | 12:55 PM
  #168
Charles4x4's Avatar
Minor progress. Trimmed Upper A-Arms to hopefully fit 32’s later this week. And installed some small stuff.
Old Aug 1, 2018 | 03:01 PM
  #169
Charles4x4's Avatar
Rear Bumper is done. It was a bear! One bolt broke off for the mounting brackets and I had to drill it out. Glad this one is done and all worked out in the end.
  #170
Charles4x4's Avatar
Originally Posted by Melrose 4r
Looking great!
I’m sure my alignment is off. I’ll do a driveway alignment once all the weight is back in.
Old Aug 1, 2018 | 03:33 PM
  #171
Charles4x4's Avatar
Rear chrome molding and mud flaps done!
Old Aug 1, 2018 | 04:38 PM
  #172
Discombobulated's Avatar
Sorry if you mentioned earlier but does this have the digi dash?
Old Aug 1, 2018 | 05:40 PM
  #173
Charles4x4's Avatar
Yes, it’s got everything the original Turbo had!
Old Aug 1, 2018 | 05:44 PM
  #174
Charles4x4's Avatar
Not Ideal! The ‘85 flawless front wheel well moldings don’t fit the ‘87 - ugh! So I did my best to fix my damaged ones and put them on till I find a replacement.
Also so installed the power antenna with the new mast.
Old Aug 1, 2018 | 06:42 PM
  #175
Charles4x4's Avatar
Spare tire is in!
Old Aug 1, 2018 | 09:18 PM
  #176
Charles4x4's Avatar
Made progress on the interior before I stopped for the night. Hope to finish tomorrow!
Old Aug 1, 2018 | 11:15 PM
  #177
SomedayJ's Avatar
Good to know, I was waiting for this post before buying them. Thanks!
Old Aug 2, 2018 | 11:28 AM
  #178
Charles4x4's Avatar
As you may have seen from my other thread on the topic, I’m a little worried about the 32x11.50s rubbing on the upper A-Arm now that the 1.5” BJ spacers have pushed the upper arm up and toward the tire more.
I trimmed the lip on the Upper A-Arm and added a thin 1/4” wheel Spacer in the front. Let’s hope they clear - abou 1“ clearance right now.
Old Aug 2, 2018 | 01:04 PM
  #179
Charles4x4's Avatar
Work was busy today. Knocked out a few small things like door locks and handles. Will get started again later tonight.
Old Aug 2, 2018 | 02:43 PM
  #180
Oh the digi dash made my day so 80’s cool!!!!!!
