87 Pickup Dash Speakers
Old Jul 29, 2016 | 10:13 AM
sweitzerworks's Avatar
Hello folk,
Just recently replaced my 87 stereo for a modern pioneer, and attempted to the replace the stock speakers for some Rockford Fosgate 4" speakers: https://www.amazon.com/dp/B001P86T1U...ing=UTF8&psc=1
Just tried to install today and they don't fit, at all. The current speakers mount with two screw, one mounts perpendicular at the bottom outside of the enclosure and the other is the cocked at a 45 at the top inside of the enclosure.
Does anyone make a decent speaker that fits here or am I going to have to do some serious modification?
I've got a 1987 Pickup XtraCab with NO speakers in the back.
Let me know,
Thanks!
-Jackson
Old Jul 29, 2016 | 10:20 AM
matt92yota's Avatar
I used the same speakers in my 92 pickup, i just cut a little off of some of the mounts on the speaker and they dropped right in. They sound great too!
Old Jul 29, 2016 | 10:23 AM
Hmm, we might have different setups, I'll take some pictures.
I'm not so convinced it's a matter of "slight" modification.
Old Jul 29, 2016 | 10:32 AM
wyoming9's Avatar
It is hard to define the meaning of slight !!!
To me a slight frame repair is building all new from the transmission cross member back
Old Jul 29, 2016 | 10:46 AM
Old Jul 29, 2016 | 10:58 AM
dbbowen's Avatar
I have an 87 4runner, but the dash is the same. I use Alpine type R speakers in all of my vehicles. These are type S because they dont make a type R 4 inch. But they work and are bolt on and 40 bucks. Heres a link.
https://www.amazon.com/Alpine-Type-S.../dp/B004TU5R1E
Old Jul 29, 2016 | 02:14 PM
ewong's Avatar
I stuffed 4" Boston Acoustics into my 4Runner.
I had to trim the basket and bend one "ear"
There used to be some "direct fit" speakers that I had at one time - Pioneer if I recall.
I got those via Crutchfield.... in 1989.
(I got the 4Runner new - and it had no radio)
Old Jul 29, 2016 | 02:57 PM
Andy A's Avatar
Think they were called a 4T speaker. Had to replace the ones in my 94 at one point and used those pioneers mentioned, long since discontinued I believe.
http://www.crutchfield.com/S-RcHId3K...-Speakers.html
Old Jul 29, 2016 | 05:05 PM
matt92yota's Avatar
The dash looks a little different but they mount the same way in my 92 with 2 screws opposite of each other. My problem was the oval shaped mounts on the speakers were hitting the plastic of the dash not letting the speakers sit flush so i just took my dremel and cut them off. And the mounting holes were off just a little so I drilled them out on the speaker slightly and they went in nice and snug.
Old Jul 30, 2016 | 10:19 AM
Pretty sure those weren't going to fit, and I really didn't want to hack em up to confirm that theory. Found a pair of blown 6x9's on the side of the road later that day, here's what I came up with:
Decent little speakers, especially with a proper enclosure. Quite efficient given they're only getting 15w RMS.
Old Jul 30, 2016 | 10:20 AM
I'm wondering if maybe these 3.5"s will fit up front:
https://www.amazon.com/dp/B001P86SP2...ing=UTF8&psc=1
Old Jul 30, 2016 | 10:22 AM
I had the same problem, however, the speaker wasn't even close to seating. The closest I could get me was maybe 3 inches.
Old Aug 3, 2016 | 11:34 AM
4RunnerFreak12's Avatar
You get it figured out?
Old Aug 3, 2016 | 01:55 PM
flagbasher's Avatar
I fit these in my 4Runner.
http://www.pioneerelectronics.com/PU...ries/TS-D1002R
They're only 25w, and I'm running 45w into them, so I don't crank it too loud.
I have the 5.25" in my rear side pockets, and the HVT sub under the seat.
They sound great. Not incredibly loud or bassy, but light years better than the original system.
I'm also using the DEH-80prs head with the auto sound levelizer which increases and decreases the volume with road noise.
Old Aug 3, 2016 | 02:49 PM
Haven't tried any other speakers up front than the 4" Rockford Fosgate.
I have a suspicion that they're smaller (3.5" maybe).
For now I'm pretty satisfied with the enclosures in the back, but if I every get around to find some speakers for the dash I'll be sure to post my finding.
Old Aug 3, 2016 | 07:14 PM
ewong's Avatar
Foam bucket behind it." />Boston 4" jammed into the 4T location.
Boston Cross Over
Dash tweeter. Yes, I drilled a hole for it.
Old Aug 3, 2016 | 07:32 PM
old87yota's Avatar
I have these speakers in my truck (with stock head unit) and really like them. I do not turn the sound up very often but they have a much wider range of frequencies than the stock speaker. Not a lot of bass but a 4" speaker can only do so much. These speakers have the right balance of sound for me.
They are a tight fit but they DO fit without any modification to the dash. All I had to do is bend one of the "ears" on the speaker to mach the angled speaker mount. Then I cut off the two unused "ears" so the speaker fits better.
Old Aug 3, 2016 | 07:52 PM
Those are sweet. I drove around for the longest time with just the little dash speakers and a 10" sub in the back. For whatever reason I kept blowing the 6x9s I had in little boxes on the back floor board not sure if ppl getting in and out or just cause I drove around with the top off anytime it wasn't raining so dust/dirt gets everywhere! Eventually wanna redo my interior panels with a spot for the speakers and some storage compartments but it's pretty low on the list for now!
Great info tho always wondered what speakers where in there, they are tiny!
Old Aug 4, 2016 | 03:32 AM
Thanks for the info guys! I'll definitely consider those Pioneers. I can certainly foresee them fitting with the bendable/breakable metal tangs.
Unfortunately my head unit only puts out 15w RMS per channel, so they'd probably sounds pretty underpowered.
Old Aug 5, 2016 | 06:07 PM
flagbasher's Avatar
I didn't even cut the tabs off. They just fit.
Like the guy above you, I've got the foam baffles behind them, too.
I put the 5 1/4" in the rear seat pockets. Much better.
I was able to fit this guy on the bottom of my Pioneer head unit. Both the head unit and amp are powered by the stock harness.
http://www.pioneerelectronics.com/PU...eries/GM-D1004
I used industrial velcro. 3M dual lock to stick it to the bottom of the head unit. They're the same width.
I had to move some of the wiring harnesses around to jam the head unit into place since it's way deeper than the stock radio, I guess. But I got it all to fit. Very tight, but do-able.
45w per channel. 4 channels.
I also ran their HVT sub and used 3/4" spacers under my seat bolts in the back to fit it under my seat. I had to wire the sub to the battery. Power went right through the hood pop grommet.
