87 Centrelink Stabalizer Bolt Rubbing on Pinion Stop
Old Apr 26, 2019 | 04:16 PM
GrimWolf's Avatar
Cool 87 Centrelink Stabalizer Bolt Rubbing on Pinion Stop
So I have an interesting issue. I just replaced most of my front end steering. I have had the vehicle aligned and while driving aroud I noticed when making a sharp left turn and steering back around to straight there was a popping noise.......pretty loud.
I lifted up the truck and had my daughter turn the wheel while I filmed the following.
What is the hive mind suggestion here? Lower profile nut and bolt? Or???
Old Apr 26, 2019 | 08:37 PM
akwheeler's Avatar
grind 1/4 inch off of the nut and stud, it looks like an aftermarket stabilizer, if you have to you can put a tack weld on the nut to keep it from backing off.
Old Apr 27, 2019 | 06:31 AM
GrimWolf's Avatar
Yeah, the shock itself is a Monroe the Centrelink is OEM though. I figured either getting a lower profile bolt and nut or griding like you are suggesting would be the best route. I'll definitely tack weld it too.
skm
10
Feb 18, 2009 12:23 AM
Extremesolo
Feb 9, 2005 09:20 AM
Yoter
Apr 26, 2004 04:26 PM
mrmojorisinphan
Apr 22, 2004 06:17 PM
Del
9
May 23, 2003 12:03 AM
