87 2wd with g662 axle code....
Old Jun 15, 2006 | 06:27 PM
spirtlanimilbus's Avatar
hello,
ive got a 2wd truck with a 3.07 ratio. im curious what size carrer bearings it has. i have seen a few carriers that have a 50mm diameter and others that are 45mm. the truck is a 4cyl 4 speed with the 2 pinion setup. i am hoping to go up to a 4.56 gear to accomodate my 31x10.50 tires. but ive heard that anything smaller than 3.42 wont fit anything larger than that. ive been looking at these...
http://store.summitracing.com/egnsea...115+4294895183
anybody have any advice on which one will fit my truck?
Old Nov 7, 2008 | 03:26 PM
JamesD's Avatar
Originally Posted by spirtlanimilbus
hello,
It is an 8" Toyota 4wd rear you have basically. You can put any gears you want into them. The G in the G662 code stands for 8" ring gear.
James
Old Nov 7, 2008 | 04:00 PM
DeathCougar's Avatar
I do not think that is an 8" diff......i have never found those gear ratio codes to be wrong, and yet this one seems to be. The G662 was for 4 speed base model trucks...that means it should be a 7.5" diff. Strange!
Old Nov 8, 2008 | 05:18 AM
JamesD's Avatar
Actually I own a G662 3rd member and it is an 8" diff. The "G" stand for 8" ring gear. I counted the splines since I got the whole axle out of a 1 ton 2wd truck and the splines are 30 just like the 4wd trucks. So he has an 8" diff.
James
Old Apr 5, 2012 | 09:44 PM
Roxana Reyes's Avatar
Not an answer but more questions. I have a 1990 Toyota 4Runner 22Re engine 2wd with a manufacture date of 08/89. The codes are G252/A44D. Everything is stock on it, but I am in need of a differential. Based on the Gcode I have an 8' 4:556 ratio and I'm wondering if I can swap a differential of a 4x4 with the same gear ration without any modifications? I am heading to the junkyard to try and find one and I don't want get something that wount fit. Any help would be great.
Old Apr 8, 2012 | 10:05 PM
JamesD's Avatar
You sure about that code? 2wd trucks never came with that gear ratio. Is the cab original to the truck? You can check to see if the VIN on the dash is the same on the frame.
James
Old Apr 9, 2012 | 06:52 AM
MudHippy's Avatar
2WD and 4WD 1990 4Runners with the 22R-E and automatic transmissions had 4.56 gears(axle code G252).
2WD 1990 4Runners with the 3VZ-E and automatic transmissions had 3.90 gears(axle code G074).
4WD 1990 4Runners with manual transmissions had 4.10 gears, or 4.56 gears if they had 31" tires(axle codes G292, G294, G252, G254)
From the 1990 4Runner brochure found here.
BTW, 4Runners don't have cabs.
Old Apr 9, 2012 | 08:50 AM
JamesD's Avatar
He said he has a 2wd truck, not a 4Runner. Where did you get a 4Runner from? 4Runner's are on a 6 lug 4wd platform even if they are ordered as 2wd, they still use the 8" rear. Also, 4Runner's never came with a 4 speed manual trans.
James
highonpottery
Aug 25, 2015 03:45 PM
DirtRoad93
Aug 23, 2015 05:50 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
falcon4runner
3.4 Swaps
Aug 6, 2015 02:36 PM
colasurdo
Jul 16, 2015 11:32 AM
