86 pickup auto transmission problem
I have a 1986 pickup the transmission shifts fine till it gets to 3rd then catches 4th almost instantly, fluids are good, solenoid is good.. it has push button O/D and with it off it still kicks into overdrive.. any ideas of what it may be ??
Kickdown linkage adjusted ok? From here you'll have to go into the valve body and see if anythings amiss. Those are like brain surgery, lots of springs, check valves, etc. so if you go into it yourself get a breakaway diagram.
It's up to you, that's a lot of miles. It is something fun to learn if you want to tackle all or part of it. There's specialty tools needed for compressing the clutch packs and pulling them out for a rebuild. Usually trans rebuilds only require new seals and o-rings, the hard parts including the friction discs hardly ever need replacement.
Here's how to decode the vin plate...
http://www.4crawler.com/4x4/ToyVIN.shtml
It should be accurate as long as somebody didn't replace the trans with something else.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
