86 22rte missing
Old Aug 20, 2013 | 05:36 PM
914runnerguy's Avatar
86 22rte missing
OK. i bought an 86 22 ret a couple months ago. The guy i bought it from said it wouldnt pass smog so he said he changed one spark plug that looked bad ( ill get to that in a minute) and did the valves and timing. I bought the truck and went to the smog shop and passed smog.
The tech said it was a good looking truck but it had a small miss around 2500 rpm. I noticed an idle miss and a miss around 2500 too.
I then replaced all plugs and wires and the tps and adjusted it according to 4crawl website.
the miss is still present and i am stumped. i know my turbo is cracked on my exhaust housing could that be the culprit? Im gonna have it shpped out to turbo electric to be serviced.
I pulled the spark plugs today and i found that #4 plug looks like Sh**. I cant understand it. it doesnt smell like gas and it was a little oily so i checked compression on the #4 cylinder again and its @ 150.
Could it be my injector? Cap and rotor? I double checked my tps and its within spec on all 4 tests. IM STUMPED AND NEED HELP
The pic with 2 plugs is #2 and 3. The other clean plug is #1 and the nasty one is #4. plugs are two months old
Attached Thumbnails 86 22rte missing-20130820_124754_resized.jpg   86 22rte missing-20130820_125205_resized.jpg   86 22rte missing-20130820_125411_resized.jpg
Old Aug 20, 2013 | 05:38 PM
I verified last night the timing is at about 5 to 6 btdc with plug jumped. I havent looked at the valves yet. OH and the truck has 182,000
Old Aug 20, 2013 | 06:01 PM
vital22re's Avatar
totally a bro
Youre burning oil it seams. I'm guessing its the valve stem seals since compression is decent. What is the compression from the others?
Old Aug 20, 2013 | 06:06 PM
compression is around 145 150.
Old Aug 21, 2013 | 08:14 AM
Bump. Please help. Pulling the valve cover to check valve clearance and seals. Will it be obvious the the seal is blown when I pull the cover?
Old Aug 21, 2013 | 06:52 PM
misaaccooper's Avatar
Valve seals, stuck ring, crack, gasket
If its def oil there are only so many options.
What are the chances it's a head gasket or crack?
Is it moded out, or still stock.
Pics help.
Old Aug 21, 2013 | 08:56 PM
Its stock. There is no milkyness in the oil and it doesnt smoke
Old Aug 21, 2013 | 11:31 PM
Since compression is good,
Must be what vital says. valve seal.
Old Aug 22, 2013 | 03:54 AM
Orion22rte's Avatar
My rte was the same, really oily plug in #4 cyl. Sounds like valve seals, another thing to check is your egr stuff. Mine was completely choked with carbon. Hope this bit helps!
But also, oil in a cylinder will raise the compression when you check it
Old Aug 22, 2013 | 01:15 PM
is it possible to do the seals with the head on? Any special tools required?
Sam hain
19
Sep 30, 2015 08:25 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
viesail
Sep 21, 2015 06:00 AM
viesail
Sep 5, 2015 04:23 AM
