6" ifs lift?!
Old Apr 18, 2009 | 04:28 PM
dayota's Avatar
6" ifs lift?!
So i had this idea getting a 4" ifs lift and then do bj spacers for like 6" of lift. For the rear use the 3.5" blocks and 2" shackles. Where will problems arise here and what shock do you use cause the longest I could find was for a 4-5" lift, will these work or will you have to shim or what?Im going to run 33x12.5 but like the look of a lil more lift than needed, im doing this for the looks, mud and snow.
Your help is appreciated and yes I've spent countless number of hours researching all about lifting these trucks.
Thanks
Old Apr 18, 2009 | 04:49 PM
yoterr's Avatar
orrrrrr you could just do a 4" with a 2" body, unless you dont like body lifts..
Old Apr 18, 2009 | 04:50 PM
waskillywabbit's Avatar
In your searching, did you find anyone who had done this?
Old Apr 18, 2009 | 04:51 PM
Matt16's Avatar
Most people who want to lift that much want it simply for looks. Is that the case.
Old Apr 18, 2009 | 05:01 PM
dayota's Avatar
Yes i did find one guy that used bj spacers with it and the thread was old and the shocks used were not specified, also yes i want to clear the 33's and then some for yes as you mentioned looks. I dont crawl anything to speak of.
Old Apr 18, 2009 | 05:03 PM
dayota's Avatar
and yoterr I do dislike Bl's cause I have to change so much but maybe.
Old Apr 18, 2009 | 05:06 PM
You don't need that much lift to run 33s. You can run 31s stock and then add a 2" body lift to run 33s since you are only doing it for looks.
The rest you want to add will just be fluff.
Old Apr 18, 2009 | 05:09 PM
dayota's Avatar
Ok i see. I do have 2" blocks that are the right size just sitting around. Do you think I could use those in the rear and then just BJ spacers in the front with maybe a little T Bar crank for 2" of lift? What shocks?
Old Apr 18, 2009 | 05:10 PM
iamsuperbleeder's Avatar
for a long while, I was planning on doing this setup, and maybe a 4" bracket lift to go with it
http://forum.ih8mud.com/79-95-toyota...936-rotbw.html
I've now settled on just installing the Rancho UCA's that I aquired in due time
Old Apr 18, 2009 | 05:11 PM
http://www.wabfab.org/products/IFSlifts/IFS.htm
Old Apr 18, 2009 | 05:13 PM
4Crawler's Avatar
Some longer shock options listed below:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
Old Apr 18, 2009 | 05:17 PM
dayota's Avatar
I may do my 2" lift idea it is much cheaper lol. BJ spacers on ebay are only like 60 shipped too so idk. Maybe this and a 2" body lift. I don't mean to stray off topic but are 2" body lifts realy that much easier and better than 3"?
Old Apr 18, 2009 | 05:22 PM
ozziesironmanoffroad's Avatar
id go with add a leaves dude, blocks SUCK
Old Apr 18, 2009 | 05:26 PM
dayota's Avatar
Is it just because blocks twist? seems it would ride better than an add a leaf. Maybe a 2" lift shackle is a better option?
Old Apr 18, 2009 | 05:36 PM
4Crawler's Avatar
Some body lift installation information discussing 2" and 3" lifts:
- http://www.4crawler.com/4x4/ForSale/...o.shtml#Taller
Old Apr 18, 2009 | 05:41 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
A 2" is not as "involved" as a 3". Here's a good site that explains body lifts and what would need to be lengthened and stuff like that. http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old Apr 18, 2009 | 05:42 PM
Ya beat me to it, 4Crawler......lol.
Old Apr 18, 2009 | 05:46 PM
blocks can and do cause leaf damage and axle wrap *edit* sorry
Old Apr 18, 2009 | 05:51 PM
dayota's Avatar
Hmmm. I see. Well it looks like I start over with ideas again haha. Im leaning toward 2" shackle lift and BJ spacers and possibly a mild BL but now you guys have me thinking again lol. Thanks so far though I appreciate it greatly.
Old Apr 18, 2009 | 06:22 PM
dayota's Avatar
Now im hearing about with BJ spacers how idler arms go out constantly and alignment is never right. Arghhh lol. Can someone convince me.
