5.29's are to low for 35's
Old Jun 21, 2009 | 06:11 PM
  #61
Mic09dcsm's Avatar
Correct, it won't fit.
  #62
Ardent's Avatar
Originally Posted by Slowstrike
Never mind I think I figured it out on meh own. The fronts of sfa are 8 inch and the fronts are 7.5 on IFS is this correct?
yes. won't work.
Old Jun 21, 2009 | 06:46 PM
  #63
Jay351's Avatar
Originally Posted by Justinlhc
I'm guessing the roads are pretty flat where you live? At 55mph in 5th gear I'm not going to be gaining ANY speed if I'm heading up a slight incline. What kind of motor work do you have done to have such a powerful 3.0? I've got headers, a free flowing exhaust and 31's with 4.30's and it has a hard time getting out of it's own way. Must be the weight difference between your truck and my 4Runner.
I'd think I had some engine issues, but it runs like a champ, has compression well above the minimum and a fresh top end. Spark plugs, wires, cap, rotor, air filter, oil and filter, all with less than a thousand miles on them.
I have your regular run of the mill 3vze. It has sea2sky stage 1 cams, catback (including a new cat) and the ISR mod. Also has fairly fresh tune up, and runs 10w-30 amsoil synthetic.
I also gear'ed my truck 4.88's and 33's. I get up to 21-22mpg on the hwy in the summertime, and I can EASILY roast the rear tires whenever I want.
And the weight savings from 4runner/pickup is pretty good too
But it is VERY hilly here, I can't accell up too steep of a hill in 5th, so 4th is needed.
I regularly go up to whistler mountain
Old Jun 21, 2009 | 06:50 PM
  #64
Jay351's Avatar
Originally Posted by Ardent
Here's a calculation to find equivalent gearing to stock when increasing the size of your tires.
New Tire Size/ Old Tire Size x Current Gear Ratio= New ratio to maintain final drive.
So, for instance, in order for me to maintain the stock ratio when putting on 33" tires, I would divide 33 by 29(1.137931) then multiply that by the original gear ratio of 4.1 and my new gears should be 4.56 (4.6655171 to be exact, but last time I checked, they didn't make those).
31s to 33s with original gearing of 4.56 would mean new gearing of 4.88.
BTW, when you put bigger tires on your truck w/o changing the gearing, this makes your speedometer/odometer say you are going slower/shorter distances than you actually are. More circumference= further per revolution. With that being said, (without arguing the accuracy of this calculation method) if you simply take your tripometer reading divided by your # of gals, you will actually get a lower number than is accurate. Does that make sense?
To keep your truck close to stock, here is what your gearing will have to be per each size tire:
manual trans:
4.10's - 28"
4.56's - 31"
4.88's - 33"
5.29's - 35"
5.71's - 37+
Thats how toyota geared the 5sp trucks
Old Jun 21, 2009 | 07:14 PM
  #65
Justinlhc's Avatar
Oh I bypassed the fact that you have a truck lol. Those cams must have made a pretty big difference? Now I'm really wondering if something is wrong with my turd because doing a burnout isn't something it's capable of. Maybe if there was dirt or water involved, but not on dry pavement.....unless I dropped the clutch at redline it might break the tires loose. I gotta look into those cams......
Old Jun 21, 2009 | 07:47 PM
  #66
Jay351's Avatar
Hehe, I dont have to dump the clutch. I just ease off the clutch and giver some gas (while holding the brake). Super easy! She doesnt have the power to keep em spinning into 2nd though
Old Jun 22, 2009 | 11:48 AM
  #67
Teuf's Avatar
i get to 3-4 junk yards a week, i have picked up some goodies here n there, some free some real cheap,,,, 85 axle front 50 bucks, no kiddin, clean 95 or so 4 runner buckets, 25 for set. hoping for an E locker or some 4.88's out of an auto 4 runner. yup i would like the 88's, stock gears n 33's not so bad, been so long i forget what stock is like,,,,,so ..70 mph, 4th gear 3000 rpm,,,,,/,,,,, 70 mph 5th gear 2750,,, 1988 PU 22re stock gears n 33/10.5s,,,,,,,Header, borla, low end cam, KnN,heavier flywheel, n tlc, when i get 4.88's i bet i say Dannnnng
Old Jun 22, 2009 | 11:37 PM
  #68
Jay351's Avatar
Originally Posted by Teuf
i get to 3-4 junk yards a week, i have picked up some goodies here n there, some free some real cheap,,,, 85 axle front 50 bucks, no kiddin, clean 95 or so 4 runner buckets, 25 for set. hoping for an E locker or some 4.88's out of an auto 4 runner. yup i would like the 88's, stock gears n 33's not so bad, been so long i forget what stock is like,,,,,so ..70 miles per hour, 4th gear 3000 rpm,,,,,/,,,,, 70 miles per hour 5th gear 2750,,, 1988 PU 22re stock gears n 33/10.5s,,,,,,,Header, borla, low end cam, KnN,heavier flywheel, n tlc, when i get 4.88's i bet i say Dannnnng
Heres some periods ................................................ Seems you can't find yours.
Old Jun 23, 2009 | 04:09 PM
  #69
Teuf's Avatar
bird. chewed. off. my. period button.
Thanks Einstein
Old Jun 23, 2009 | 07:51 PM
  #70
Jay351's Avatar
Now he finds it...
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Longbed 90
Mar 11, 2019 12:38 PM
Boomer8404
Sep 10, 2015 09:01 AM
justdifferentials
Sep 5, 2015 06:52 PM
