4Runner starts but dies after a few seconds
Old Sep 13, 2007 | 07:44 PM
CC_yota's Avatar
I was cleaning the intake and K&N filter on my 95 3.0 this evening. I disassembled the intake, sprayed it down with throttle body cleaner, cleaned my K&N. I made sure all clams were tight and all vacuum hoses were connected, and reconnected the MAF. Now it starts and starts well, but only runs for a couple of seconds and dies? Any Ideas of whats wrong?
Old Sep 13, 2007 | 07:48 PM
Kaleb's Avatar
Did you clean the MAF?
Old Sep 13, 2007 | 07:56 PM
Kiff's Avatar
is the MAF connected? Sounds like it's firing on the cold start injector, then not getting and feed for air intake so the injectors aren't firing. Or MAJOR vacum leak
CC_yota's Avatar
Yeah cleaned the MAF, and have gone back through and checked all of the hose clamps and vacuum lines again. It did the same thing when I changed the plugs but I had forgotten to hook a vacuum line back up.
Old Sep 13, 2007 | 08:01 PM
CC_yota's Avatar
Yeah everything is hooked up the way it was before I started...
Old Sep 14, 2007 | 12:31 PM
4runnerx3's Avatar
Make sure the oil pressure sending unit is good/plugged in, if the ECU doesn't see any pressure it shuts down.
Old Sep 14, 2007 | 01:02 PM
GVOLCRunner's Avatar
Just another thought.. you might have done something to your mass air flw sensor.. if that goes out.. or goes bad.. you wont run.
Had a similar experience.. and the conditions you talked about exactly.. would start.. then die.
go to your jumper/testing relay box by your engine relay box under the hood and jump fp+ to b+.. this will bypass your MAF and send power straight back to your fuel pump. If it starts, you know its your air flow senso.
Old Sep 14, 2007 | 03:18 PM
CC_yota's Avatar
That was it. Found one at an import yard for $100, she runs great now. Thanks for the help!
Old Sep 14, 2007 | 07:26 PM
longhungsilver's Avatar
what did u clean it with?? did u pop off the black housing and clean inside?? if so what did you use.. or wut exactly did you do (so others dont make the same mistake..)
Ive cleaned mine out (using electrical cleaner) and then i resealed the black lid housing up with sealant after...
Old Sep 15, 2007 | 01:05 AM
CC_yota's Avatar
It looks like one of the pins broke off of the MAF at the connection, more than likely my fault but not sure how it happened. I was actually just going to clean the air filter, but decided while I was there I would clean out the intake box and tract considering the shape of the filter. I didn't clean anything electrical on the MAF. Should I? And if so what type of sealant should I use when replacing the housing?
sonic concepts
Aug 16, 2025 03:13 PM
91toybeater
Dec 27, 2015 07:46 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
ibayne
Jun 26, 2015 06:30 AM
bobbybouche
Jun 18, 2015 10:22 AM
