4runner removal top question
4runner removable top question
so i just took the removal top on my 4runner for the first time and noticed there were only 8 bolts holding it on "no wonder i could here it twist over certain terrain " just wanted to confirm that there should be 14 bolts holding this thing on and that all the bolts are the same size and length ? also the holes that were missing bolts is it possible the threads are gonna be a little tough to screw a bolt in because i cant seem to screw them in by hand ? just wondering if i should get it started in the threads then put a ratchet and socket to it with a little pressure , i dont wont to mess up the threads , any one have this problem ? thanks.
i wouldn't try threading into those tough spots with a ratchet and force things. i would suggest inspecting the threads and cleaning them up before trying that. ideally, you should chase the threads with a tap and some oil. if you don't have one, you could try a wire rotary brush on dremel (or even a spare bolt) after soaking the hole with penetrating oil to loosen up the corrosion.
Its on the drivers side maybe second from back.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
