4runner diffs in pickup??
Old Oct 15, 2014 | 04:26 PM
shepsyota's Avatar
Ok im pretty sure this will work but thought id ask. I have a 93 pickup with manual hubs and want to install diffs out a 4runner from junkyard with 4.88 but is has vaccum lock motor on front diff??? So i just use the tubes and axles from my original front diff on the 4runner 3rd member??? Its a lot cheaper to get gears this way. Lol
Old Oct 15, 2014 | 04:28 PM
JasonYota's Avatar
Yes, you don't even have to swap the tubes unless you want to though
Old Oct 15, 2014 | 05:27 PM
shepsyota's Avatar
So just swap the whole thing and it will work fine with my manual hubs
Old Oct 15, 2014 | 06:12 PM
JasonYota's Avatar
Yep. You will have to fasten the shift collar to stay in the locked position on the ADD diff. That's what I'm going to do when I install locking hubs on my 4Runner.
Old Oct 16, 2014 | 10:09 AM
Fraser's Avatar
That is definitely one way to do it, but I know personally if I had the whole assembly out of the truck I would swap the non-ADD tube and axle to the new diff. (and in fact I have done exactly that) It's nice to get rid of one more potential point of failure for the 4wd system.
Old Oct 16, 2014 | 10:55 AM
shepsyota's Avatar
Thanks! That was my thinking. Just swap my tube and axles and roll on. Now is the add made attached to the tube or seperate on the housing? Just curious once i swap my tube if i leave that on there or it comes off. Thanks
Old Oct 17, 2014 | 05:35 AM
Fraser's Avatar
The ADD unit is attached to the axle tube.
Old Oct 17, 2014 | 05:59 AM
rattlewagon's Avatar
Does that help?
vasinvictor
Jan 20, 2016 12:39 PM
Valvoman
Jun 28, 2015 02:45 PM
Niameyrider
Jun 25, 2015 05:50 AM
P51warrior
