4runner Brake Valve raise bracket
Old Jun 25, 2009 | 06:17 PM
Alex 400's Avatar
How tall is that brake valve bracket on your guys 2" rear lifts? I didn't get it with my all pro coils and was going to make one.
thanks
Alex
Old Jun 25, 2009 | 11:58 PM
Alex 400's Avatar
bump...
Old Jun 26, 2009 | 12:15 AM
894x4pickup's Avatar
Im assuming your talking about the LSPV rod that is attached to the axle...
But lets see....if you raise the rear 2", you might want to raise the bracket 2" to set it back to stock for maximum braking power...
In my case, its a little different cause its a pickup, but i just welded a little piece of flatbar so it was back to its closest to stock position...i say closest cause hit the ebrake line when it was exactly stock...
Good luck! alot of guys on here just use the cheapest method that is available, like plumbers tape or similar...just whatever it takes to get CLOSE TO STOCK.
Old Jun 26, 2009 | 02:17 AM
abecedarian's Avatar
yup. all you need is a bracket you can bolt in place that compensates for the amount of lift you have.
I bought some perforated steel strap, not plumber's tape, from Home Depot. I think it's 1" wide, 1/16" thick and has either 1/4 or 3/8 holes up its length. I cut it into about 6" long pieces, bolted two pieces together to make it double thickness, then cut through the ends and made it look like a tall "H" with a thick middle. That way I could slide it up or down and adjust things without dealing with the adjuster on the arm.
Here:
Old Jun 26, 2009 | 07:40 AM
Alex 400's Avatar
Here:
there we go. I just wanted to make sure there wasn't a weird ratio between lift and the height of that bracket. alright thanks guys.
Old Jun 26, 2009 | 01:17 PM
Thats what i was trying to think of ...man i gotta go to bed earlier...
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
HRDC0R19
Jul 5, 2015 06:43 PM
