4runner is back on the road!! Pic....but a couple problems.
Old May 31, 2008 | 08:33 PM
vmax84's Avatar
Finally got the old girl back on the road. Total rebuild. Runs very good so far (22re). I had it professionally bored "20 over" and also had the crank turned and new pistons, rings, brand new cylinder head, etc.
I do have some sort of electrical glitch, however. Whenever I "load" the alternator with a quick load (going from off to high with the fan switch), the engine will cut out just a little.......almost like I'm bogging it down with the current load. Weird. Otherwise, engine runs great.
Also have a problem with the high/low switch for the headlights. The high beams always work, but sometimes the low beams won't come on unless you work the switch a little (cycle it on and off a few times).
vmax84
Old May 31, 2008 | 08:36 PM
vmax84's Avatar
Now that I think about it, I didn't hook up the ground wire going from the back of the cylinder head to the firewall (wire was junk). Maybe I should start with a new wire and see what that does.....I'll have to ask the two clowns in the pic and get their advice!! They love riding in the truck.
vmax84
Old May 31, 2008 | 09:54 PM
iamsuperbleeder's Avatar
Originally Posted by vmax84
...I'll have to ask the two clowns in the pic and get their advice...
hahaha
that's a fine looking runner man; at least you decided to keep the 22re, not swap it out for the 3.4 or something, lol.
Old Jun 1, 2008 | 05:18 AM
wardriver's Avatar
As stated before check the ground wires to the engine block. They could have been easily missed when re-installing the engine. Also while you are at I'd check the ground from the battery to the body, and the 12+ from the battery to the fuse block. I've seen another post floating around here where people experienced similar issues - engine cutting out under a load. They replaced that wire and all was good.
Old Jun 1, 2008 | 05:23 AM
vmax84's Avatar
Thanks a lot. I'll check those later today after I get the "little clowns" their pancakes. The day always goes much better after a good breakfast!!
vmax84
Old Jun 1, 2008 | 05:28 AM
wardriver's Avatar
Ah...found it. I know you're rocking a 1st gen - but the issue could be the same idea. Link
Old Jun 1, 2008 | 07:32 AM
vmax84's Avatar
Thanks a lot for the link. As soon as my dial up loads all this stuff, I'll be in business!! Gotta walk away from the computer while this stuff loads up and get some laundry done.
Thanks again.
vmax84
Old Jun 1, 2008 | 08:08 AM
phildelfino's Avatar
I ran across that write up a while ago and wanted to do that to my 1st gen 4runner just to be on the good side of the power gods. It is very simple to understand and follow and gives great detail for the process.
Old Jun 3, 2008 | 02:31 AM
vmax84's Avatar
Update:
Ran a couple extra ground wires from the cylinder head to the frame and then off the negative terminal to the frame. Totally solved the problem!!
Thank you for the great advice.
vmax84
Old Jun 3, 2008 | 08:33 AM
kcrunner's Avatar
Nice rebuild man! Any chance of you throwin a couple more pics of the overall truck?
Also, did you repaint, or do you have a Texas truck?
Old Jun 3, 2008 | 03:00 PM
coryc85's Avatar
I think your headlight problem might be dirty contacts. Check 4Crawler's website for more info on that.
Old Jun 3, 2008 | 03:08 PM
1stgen4gunner's Avatar
holy crap you have exactly the same truck I do, the same color even, cept I got a 3.0 and 31's, it no one knew that they wouldnt be able to tell the difference.
vasinvictor
Jan 20, 2016 12:39 PM
red88toy
11
Aug 3, 2015 07:47 PM
Wid
Jul 1, 2015 11:54 AM
Niameyrider
Jun 25, 2015 05:50 AM
