#4 Injector leaking (spraying)
So I had to replace my HG and at the same time I did the timing chain and had the injectors cleaned and match flowed. Well I got it all back together, used gas to lubricate the o-rings and all. Fired it right up, when I shut it down I heard some spraying, the #4 injector is spraying fuel from about 1/3 of the o-ring side.
Is there anything I can do other than remove the fuel rail and try again?
Blamalam
Mar 12, 2022 07:34 AM
pyramid
Jul 30, 2015 10:05 AM
