#4 Injector leaking (spraying)
Old Apr 4, 2007 | 08:22 AM
AH64ID's Avatar
So I had to replace my HG and at the same time I did the timing chain and had the injectors cleaned and match flowed. Well I got it all back together, used gas to lubricate the o-rings and all. Fired it right up, when I shut it down I heard some spraying, the #4 injector is spraying fuel from about 1/3 of the o-ring side.
Is there anything I can do other than remove the fuel rail and try again?
Old Apr 4, 2007 | 08:30 AM
Ringmaster's Avatar
Think the only choice you have is to pull the rail.
Use a touch of engine oil as a lube.
Old Apr 4, 2007 | 09:25 AM
AH64ID's Avatar
doh!!! And I was alomst done with the truck
Old Apr 4, 2007 | 12:48 PM
DudeBud's Avatar
yes use oil on the o-rings, also make sure they are tight on the injectors.
Old Apr 4, 2007 | 03:19 PM
SoCal4Running's Avatar
You could try to rotate it slighty, maybe the seal is pinched alittle. They should spin freely anyway, so if its tight no bueno.
Old Apr 4, 2007 | 03:22 PM
95RunnerSR5's Avatar
x2 on the oil i used just enough to cover my o-rings and they work fine
Old Apr 4, 2007 | 05:45 PM
AH64ID's Avatar
I just popped the intake manifold off, the o-ring was bad... had a flat spot. New o-ring and away it went....
now to find my timing light.
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
pyramid
Jul 30, 2015 10:05 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
