4.88's!
4.88's!
Well last night I went and pulled a entire diff. assembly out of a 94' 4runner with stock 4.88's. I also got the entire front assembly from hub to hub. I have never seen a cleaner vehicle in my life. Only 150.000 miles on it garage kept and never offroad. the gears looked bran new! they still have allthe factory markings on them. I am so excited and I am puting them in today. I will post pictures later. These should be a very nice change to the 4.10 I run now. P.S. both only cost me 500 dollars
I wish I could find some 4.88s out of a runner for that much around my area or on some message boards somewhere. I have been looking for some gears or maybe even a locker too.
What size tires are you running? are you driving a truck or 4runner?
I'm putting them in a 86' 4Runner. I will post some pics today. I have brand new 33x12.50 BFG Mud Terrains on cragar soft 8's. but I will Probably be selling the 33's and going to a 35. I have a 5" suspention lift to go with it.
7-10yrs ago parts for the truck/4runners up to '95 around here were kinda pricey but now most stuff is dirt cheap cause no one's looking for it anymore. A guy that owns a small volume toyota/import yard fixes me up with great prices since I see he about every other weekend.
He use to get tons of those early/mid toyota's but lately not so much. It could be a while till another 4.56 or 4.88 truck shows up. As for warrenty, why would you need one for a 3rd??? A simple look over the gears and bearings is all you need. Carrier bearings rearly go bad and either way you should put in a new spacer to set pinion bearing preload and you should increase the carrier bearing preload on used gears. Front's don't see much use and mileage isn't always a true judgment of the condition. I just don't get the drive for warrenties, such a gluteness american tradtion, just make sure of what you'r buying and for $200 it's not worth the time. --Acutally I could see the worries if you buy stuff from a yard that makes you take what they have and you can't choose or see what they came from.
I'm still thinking about putting the 4.88s in the truck. I'm running 33x10.50s with 4.10s right now. I could feel a difference when I put the 33s on but it's not anything that I can't live with but I would love to have more power. I'm only worried about losing more gasmileage due to the higher RPMs with the 4.88s.
Well got the whole front assembly put on! the rear is still on blocks. The wheel barrings on the drivers side were shot. I bought all new seals and barrings. I took them to a machine shop near where I was doing the work and the guys said they would have then done by closing.... well 830 rolled around and eveyone split. So I looked up the guys home phone no. to ask what the f@@cking deal was. He took them 40 minutes away to get pressed out. Ends up he took them to the same town where I live! Idiot... so after some choice words we were somehow disconnected. I'm going to the other machine shop myself this morning to pick them up and install. All I have left is to bolt the axels and attach the brake lines and give those 4.88's hell!
