4.88 Toyota 8" axels
Im probably beating a
but I couldnt find it in search Ive seen it before but I dont know where, what toyota has the toyota 8" 4.88 geared axels? and will they fit my 94 toyota 4x4 pu? How much do these used axels run for? thanks
They were in V6 auto's with tow package and stock 31" tires. The third member will bolt right in. Not sure what they go for, I will probably be selling mine sometime this next year when I regear. If you didn't already know, the rear third with stock 4.88's can not be regeared, only locked.
anything from 90-95 with an auto and 31's will have them.
NOTE: The thirdmember for these gears are TOTALLY different - they have an offset pinion. There are NO other gears that fit in these thirds. Personally, I would get gears for your current diff - a lot more choices down the road.
ok cool, but know one knows the price of the third member? I'm not going bigger than 33"s considering my longtravil kit works best with 33s, but just curious, why cant you regear yhem?
The 3rd member has a different pinion offset so that the ring gear doesn't need to be as thick. This means that no gears other than the factory 4.88's will fit.
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
toyoda8488
Jul 5, 2015 10:18 PM
