3zve please help me locate a gasket number 1994 4runner 4x4
Old Dec 3, 2013 | 08:58 PM
mattesonb's Avatar
I have some coolant leaking out on the connection from the radiator to the water pump and it is making me nervous. i would like to open it up and replace the gasket but for the life of me i can not find a diagram with the part number.
here is the location (dead center where the white coolant is, this isnt my vehicle though)
and a shot of the other side of the hose
Old Dec 3, 2013 | 09:07 PM
YotaWoRx's Avatar
Use silicone sealant in the groove....
Old Dec 4, 2013 | 05:53 AM
Gevo's Avatar
so you're going to take the water pump off to replace the gasket? Make sure you inspect it for damage!
Go to toyotaoverstock.com it's relatively easy to find what you are looking for there from the diagrams.
Old Dec 4, 2013 | 08:44 AM
scope103's Avatar
There is no gasket there. Silicone is good, but I use RTV "for water connections."
Old Dec 4, 2013 | 09:49 AM
mattesonb's Avatar
I'm not removing the pump, just the connection where the hose exits and heads to the radiatior.
It's leaking a little bit
Old Dec 7, 2013 | 11:13 AM
domitus's Avatar
In the future, if you need Toyota part numbers you should check out this site:
http://japan-parts.eu/
Enter your VIN and it will give you extensive diagrams with a really good interface
J
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
94hiluxZE
Jun 22, 2015 10:42 AM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
