3VZE turbo
almost to 300k on mine and runs like a raped ape, of course ive had it apart a few times and everything is ported. only thing left is the bores but i still have great compression so hopefully ill make it to 400k. also replaced crank with a forged unit after the first one broke at redline and much to my suprise didnt do any other damage.
me too seems like it would be fun. anyone know what the atmospheric pressure difference between 6000ft and sea level in pounds? thinking a low boost turbo would be ok as long as it booste3d low psi to compensate for altitude like our kubota diesels with high altitude turbo compensation
yea your right but i was thinking drive pressure too, dont want it to be too laggy but at the same time if im only after 3lbs than i can use a bigger turbo that wont boost right away but also wont be inefficent like a smaller one with higher drive pressure and wasgating most of it. if that makes sense. so i did a little research and its only like 2 to 3 pounds of atmospheric difference between me and sea level
#25
xxxtreme i see what ou mean you may have misunderstood. that is exactly what they are for. my question was to ask the difference in pressure between here and there to see how much i could get away with with the stock fuel system. as far as the kubotas they were NA before at sea level but wouldnt pull worth a crap at altitude so td025 turbos were installed. one that see heavy loads has the gate disabled and is probably overspeeding the turbo like crazy but it runs cool and doesnt smoke at ridiculous boost levels
#26
Not sure what you mean by drive pressure as it's the exhaust driving the turbo to begin with. I would assume that regardless of altitude exhaust pressure is pretty much gonna stay constant sine boost stays constant. As air pressure goes down that means the wastgate has to send more exhaust flow to the turbo to spool it faster thus maintaining boost. Only thing I can think of is a possible and probably negligible change in lag since the wastegate at higher altitude would have to fluctuate more then it would at sea level.
Of course like you said it all depends on what size turbo your going with and what boost level your after. If your running at pretty much max turbo RPM for a given boost level at sea level as soon as you go to a high altitude your over spinning the turbo or the wastgate can't compensate enough exhaust flow to keep your desired boost.
Smaller turbos spool faster then larger ones, however larger ones can maintain a higher boost pressure for a given RPM. Problem is changes in altitude are gonna affect a larger turbo more then a smaller one. It's also gonna depend on the displacement of the engine as well. Fine line and ya really got to know what your doing. Running a T3/T4 at 4psi on a 22re is kinda pointless as it's gonna lag big time. And running a TD05 on a Big block chevy isn't gonna maintain boost at least not without overspooling the turbo.
#30
my god all this turbo stuff is bringing back all my import/scca days geeezus. But then again iy my BMW didn't have 250K on it that thing would have been turbo'd by now. It's a perfect platform for it.
#34
what about a remote turbo like the one sts have for the 5vz?
v band turbine and all other stuff are available in ebay at a good price,
it hink is more simple to do the down part is the issue oiling the turbine,the price of the pump to move the oil back to the engine is a little high.
maybe a sealed loop oiling system can work.
lets get creative and see what happens
and yes i have a 3vze and for me is a very durable engine if mantained properly as anything that need to be.
#35
No i didnt say into 2nd and 3rd. Haha that would never be possible. I said i can spin them in first easily if i dump the clutch and while quick shifting into 2nd and 3rd it will chirp the tires. Sorry a little miss leading.
#36
1.) Not sure what you mean by drive pressure as it's the exhaust driving the turbo to begin with.
2.) I would assume that regardless of altitude exhaust pressure is pretty much gonna stay constant sine boost stays constant. As air pressure goes down that means the wastgate has to send more exhaust flow to the turbo to spool it faster thus maintaining boost.
3.) Only thing I can think of is a possible and probably negligible change in lag since the wastegate at higher altitude would have to fluctuate more then it would at sea level.
2.) It will if we're talking about gauge pressure and not absolute. Take a 10psi wastegated setup from sea level to 12,000ft and it's still going to make 10psi on the gauge. It will make less power because the absolute manifold pressure will be lower by the difference in atmospheric pressure.
3.) The wastegate is always shut until the set boost level is reached, so I don't think it would affect lag due to altitude. Altitude is going to make for less air going into the engine before spool so there will be less exhaust to get the turbo spun up, though.
As an altitude compensator, I think a Rootes blower would be better even if it has no inherent ability to automatically adjust.
As far as a turbo 3VZE, I wouldn't touch one with a 10ft pole. It's fun to discuss, however.
#38
you can get a forged one by using a 3vz fe crank. the 3vz have the strongest blocks out of all 3 generations. saw another guy state this and i agree. the best combo would be 3zve block with 3vzfe crank and 3vzfe heads or 5vz heads with 3vzfe cams. the 3vzfe cams have a bit more lift and duration than the 5vz and give you a long flat torque curve earlier and will pull hard. if you want a forged crank or the best crank for a 5vz or 3vz use a 3vzfe forged unit from an early nineties camry
#39
Do you know of any mods i can do to get some of these vacume lines out of my engine bay?
#40
wheel hp and crank hp are two different animals due to parasitic drivetrain drag. and the 3vzfe crank is a drop in in the 5vz and 3vz blocks. the heads for a 3vzfe will work on a vze block with minor work and a plenum off a 3.4 you could put fe heads from a 3vzfe on a 3vz block with a slight bore with 5vz pistons and get a 3.4 with a dizzy that will run off the stock camry ecu.
