3VZE O2 sensor?
Old May 21, 2007 | 08:25 PM
CoedNaked's Avatar
3VZE O2 sensor?
I've heard some poeple in here suggest that you can have a bad O2 sensor on the 3vze equipped trucks, and it might not throw a code. But could it be the source of a slightly rough idle as well i.e. have you replaced your O2 sensor and it improved your idle and you noticed it helped your gas mileage? Also, isn't there some way to check your O2 senor like measure it's conductivity or something like that?
Old May 21, 2007 | 08:35 PM
thook's Avatar
Yeah, you can check it with with an ohm/volt meter against the specs in the online FSM.
Interesting, I've never heard of a bad O2 sensor not thowing a code. If it's bad, the ECU should pick it up. However, just because the ECU may be throwing an O2 code doesn't mean it is bad. Just that the sensor is detecting something is wrong in the exhaust mix.
A bad O2 sensor can be the source of a rough idle, but like I already said something else may be the real source. I've replace them before and it did improve how the vehicle ran initially (idle, mileage, power, etc.), but the problem soon reappeared because something else was bad....like the engine coolant sensor or leaky cold start injector.
Old May 21, 2007 | 10:05 PM
curly_c's Avatar
im having one shipped to me right now. im hopping that it helps my idle and my gas millage. i really need the help in the MPG department. i tested it and it was on the very edge of the specs. so i got one anyway. its nice to know when something was new and when you put it on. not just hoping that the owner before you did.
Old Jul 18, 2010 | 04:51 PM
Toreador's Avatar
how many o2 sensors does the 3v-ze have?
where are they located?
pics?
Old Jul 18, 2010 | 05:59 PM
thook's Avatar
It depends on the model and year. That I know, but I don't know the specifics. As far as location, they will be on the exhaust underneath the vehicle midstream........one before the cat and, if you have two, one after. Might wanna crawl underneath and look.
Old Jul 19, 2010 | 11:55 AM
Toreador's Avatar
for my 1995 4Runner SR5
do i have an o2 sensor somewhere near the engine?
the only o2 sensor i can find on my vehicle is the one near the cat. it's right BEFORE the cat.
i ordered 2 sensors, both denso, one for the "front" and "rear"
can someone tell me where the "upstream" o2 sensor is?
and the best way to access it
Old Jul 19, 2010 | 01:40 PM
Toreador's Avatar
couldn't see anything other than the one near the cat,
so i am assuming there is no o2 sensor near the engine
meaning my truck only has one
thanks
Old Jul 19, 2010 | 01:59 PM
Fink's Avatar
You should only have one IIRC.
Fink
Old Jul 19, 2010 | 02:14 PM
sb5walker's Avatar
The only trucks that have two O2 sensors are the California trucks, which have one before and one after the cat. All others should have only one.
Old Jul 19, 2010 | 03:10 PM
scope103's Avatar
Originally Posted by sb5walker
The only trucks that have two O2 sensors are the California trucks....
Correct; this is so the ECU can test whether the Catalytic Converter is working (as the upstream sensor switches back and forth, the downstream sensor should be doing nothing, because the Converter reacted all the oxygen).
Old Jul 19, 2010 | 03:14 PM
Fink's Avatar
On Cali vehicles I believe the front sensor is an A/F sensor too, that's what my '99 had anyway.
Fink
Old Oct 26, 2013 | 08:36 PM
mmetzgier's Avatar
i cant seem to find a part number for the upstream o2. can anyone help me?
Old Oct 26, 2013 | 08:52 PM
ksti's Avatar
This thread is pretty old.
www.densoproducts.com
Old Apr 17, 2014 | 12:20 PM
iwanna4banger's Avatar
I replaced my coolant temp sensor and soon to be o2 sensor. That and new exhaust maybe it'll actually pass emissions...
moparbay
Mar 10, 2023 03:50 PM
MadMax48
Mar 3, 2020 10:33 AM
Longbed 90
Oct 19, 2015 11:05 AM
EatChipsNow
Sep 9, 2015 01:25 AM
