3vze manual tranmission flush. help!
Old Jun 29, 2009 | 10:53 AM
chrisspliff's Avatar
Hey.
So my next project on my 90 pickup 3vze (170k) will include fludshing my manual transmission fluid and replacing it with synthetic (royal purple) fluid. I have a few questions:
Firstly i cant find any links to picks for the job, so if you know any please share.
Secondly... Im not sure if a flush is necessary, im changing to synthetic so it may be. Also do i need to replace the gasket and screen or can i get away with just cleaning it? Im hoping to get away with just a drain and refill. Im a mechanic in training lol so step by step instructions would be great!
Also.. i believe i can use the same fluid for my transfer case???? Any links to that job would be great
Old Jun 29, 2009 | 11:12 AM
Tubbyfatty's Avatar
I dont think you need to flush it to go to syn fluid. When i change mine im just gonna drain out the old stuff then fill it up with MT-90.
Old Jun 29, 2009 | 12:50 PM
Jay351's Avatar
No need to flush or anything like that. Transmission flushes are a money grab.
Just remove the 24mm (all the diffs and tranny/t-case plugs are 24mm) fill plug first, then remove the drain plug.
Drain all fluid and fill till it comes out of the fill hole. Make sure you use the correct GL4 fluid. Most guys like to run redline mt90, some of the best stuff you can buy for your yota. I run all Amsoil synthetics in my drivetrain
Old Jun 29, 2009 | 01:13 PM
Tubbyfatty's Avatar
x2 on the fill plug first!!! If you cant get it off then you know before all the fluid is out haha.
Old Jun 29, 2009 | 01:31 PM
Thanks guys!
Im gonna use Redline MT-90 looks like good stuff!
Any1 know the capacity for diff,transfer case and trans? I think there will be a quart or two of un-drained oil.
Old Jun 29, 2009 | 01:46 PM
Tubbyfatty's Avatar
Originally Posted by chrisspliff
Thanks guys!
Idk about your rig but heres mine
Trans, R150f - 2.3qts
T case, 3vz - 1qt
Rear diff 8'' - 2.3qts
Front Diff - 1.9
You can fill mostly everything till it comes out the fill plug.
Its all 75-90 but you can run a heavier oil in the rear diff if its hot year round where you live.
That MT 90 stuff is like 12 a qt btw. Its what i paid yesterday.
Old Jul 1, 2009 | 07:01 AM
Mic09dcsm's Avatar
Call me a lazy ass, but I've had my Redline for a year and still haven't changed the fluid. Gonna do it today finally...and when I bought it it was only about 7 bucks a quart.
Old Jul 1, 2009 | 07:10 AM
lofreqjeff's Avatar
Dumb question - how often do you guys recommend doing this?
Old Jul 1, 2009 | 08:56 AM
Tubbyfatty's Avatar
When ever you feel like it? haha idk.
Im just doing mine because I havent changed it since I got it, the tranny is out cause im doing the clutch, and it cant hurt anything haha.
Old Jul 1, 2009 | 09:02 AM
lofreqjeff's Avatar
I've never done mine and I've had it for over 4 years.
Probably something I should do sooner than later.
Old Jul 1, 2009 | 09:29 AM
Tubbyfatty's Avatar
Im not saying it should be done, but its not as important as the automatics are. Automatics are alot more complicated then the manuals.
But yea, its easy, 24mm wrench, 2 bolts, your basically done haha.
Old Jul 1, 2009 | 02:28 PM
Here a link to the a service manual for maintenance reference:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
As soon as i get some $$'s together i will do the fluid swap. Expencive but im excited
90 Toyota Pickup 3vze, Borla catback, Deckplate mod, ISR mod, 32" BFG KM2 M/T's, Smity Nerfs, K+N Air, Kenwood x990 Deck , MTX 10" in MTX Sledgehammer Box, Soundstream Amp
Old Jul 1, 2009 | 02:46 PM
Tubbyfatty's Avatar
you can throw that in your signature. Click on "user CP" at the top, then on the left side "edit signature"
Old Jan 30, 2011 | 01:54 PM
dsleggett's Avatar
My transmission capacity seems different than the FSM states. Anybody else fit too much fluid in theirs? 1994 4Runner, 3vze, manual trans (R150F) and 4 wheel drive. The manual quotes oil capacity for the R150F trans as 2.3 quarts. I put almost 3 quarts in and it's not leaking out of the fill plug yet. Front diff (1.9 qt) and transfer case (1.1 qt) were right on the money. I made sure to jack the rear up so the vehicle is level (driveway has slight grade to it). I haven't gotten to the rear diff yet, I'll probably wait until it's snowing and 10 below. I drove to work today and I'll pull the trans fill plug tonight and see if anything leaks out, hmmm.
HINT: go to the dealer (NAPA, Autozone, Checker don't have them) and get the proper drain and fill plug gaskets BEFORE you start this job. They're about $1.50 each but should make a difference. Trans and Xfer case are aluminum crush washer and diffs use a steel crush washer. Of the six I've pulled off so far (make that five, front diff drain was missing a washer and leaking, surprise) all were wrong. Grease monkey has been changing the fluids the past few times, ugh. Missing washers, drain plug inserted in fill hole (drain plug is magnetic) and other stuff makes me glad I've taken the time to do it right this time. I've been religious about changing fluids every 40-50k miles and owned the truck since new. All of the fluids so far looked good, I could see through them as they drained, not black, just amber. I think the lube shops only have GL-5 lube too. I put GL-4 in the trans and it seems smoother already. GL-5 in the diff.
I've put this off for six months, who wants to fix stuff when the weather is nice and you can see until 8:00 pm in the summer time. No, I waited until winter when it's much more fun...
Old Sep 17, 2013 | 09:18 AM
nuttynu's Avatar
So you can use mt -90 on auto transmission too instead if regular ATF ?
Old Sep 17, 2013 | 10:33 AM
dsleggett's Avatar
NO, use ATF. Check the FSM for correct specs.
Old Sep 17, 2013 | 10:56 AM
nuttynu's Avatar
Wink
Thanks !!
Checked my level & everything looks fine. May still drain it and put new fluid tho.
Cheers.
Old Feb 28, 2020 | 03:20 PM
Cameron Croucher's Avatar
Out of manual
Flossy
Aug 5, 2015 05:14 PM
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
smiley52
Jul 11, 2015 05:16 AM
