3VZE - Fast Idle Air Valve (Problem and Location)
Old Oct 14, 2015 | 11:12 AM
warrenjcarlson's Avatar
Solution!
I recognize a'lot of the issues people are mentioning on here. I have been experimenting with my intake isr mod and found a few things...
1st: some worn engines have leaking rear main seals, the vacuum on the valve cover hides this until it gets really bad. However, this causes air to come through the rear main seal and into the intake screwing up your air to fuel ratio.
2nd: Removing the valve cover breather to fix this problem will cause a HUGE leak to appear in your bell housing (trust me I've done it)
3rd: To fix this? rebuild the engine.. To temporarily hide it for another 100k? Open the VAFM and richen it up a bit to compensate.
Hope this helps someone, please post if it does...
Old May 31, 2016 | 10:15 AM
hayder's Avatar
hi i need a map of air line of 3vze engine of toyota surf ssrg 1992
Old Apr 24, 2020 | 03:00 AM
Benny Bones's Avatar
What does the BVSv look like?
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
