3VZE Engine Overhaul, Ok To Use Stock Manifolds??
Old Mar 1, 2019 | 05:52 AM
Rpowell600's Avatar
Just finishing up an overhaul and I have some cheap ebay headers sitting in the garage. I cant fork out the money for $600 plus headers at the moment. I need to keep EGR so I would have to fabricate a tube to run the EGR valve on the ones I have here. Im also concerned with heat on the brake lines and fuel lines. Is it worth the trouble to install these headers or would I be ok with running the stock exhaust manifolds?
Old Mar 1, 2019 | 07:05 AM
Melrose 4r's Avatar
5 Year Member
I'll comment on your heat question. I have the headers wrapped on my Camaro and it's amazing how well the wrap reduced the underhood temp. A roll of wrap is about $25 from summit and will do one V8 -sized header. You use stainless steel tie wraps to hold it in place. You can get the stainless tie wraps from home depot or lowes or summit.
Old Mar 1, 2019 | 08:23 AM
Rpowell600's Avatar
I have some rolls of titanium header wrap. Just the headers here being "cheap" and the fabrication required may not be worth all the hassle for no gains. I have heard of the crossover causing head gasket issues but yet there are 3.0's out there with 150-200k on them with no issues running stock everything. If I can return these and get my money back without setting myself up for failure that is the goal.
Old Mar 1, 2019 | 08:33 AM
scope103's Avatar
Originally Posted by Rpowell600
... or would I be ok with running the stock exhaust manifolds?
... return these and get my money back without setting myself up for failure that is the goal.
Your 4runner has run for 24 years with the stock manifold. Yeah, I suppose you might only get ANOTHER 24 years out of them before you need to go out and buy an aftermarket replacement. :^)
But I think you can wait until then to decide.
Old Mar 1, 2019 | 08:36 AM
Rpowell600's Avatar
My thoughts exactly! I guess I wanted to hear someone else say it lol. Although the internet has plagued the stock system as "the worst engineering ever". Ill keep it stock for now.
Old Mar 1, 2019 | 10:52 AM
old87yota's Avatar
I agree with Scope103.
The stock manifolds are fine and will work with your EGR system without the need to fabricate anything.
The 3VZ-E, while not the absolute best automotive engineering, they are far from being bad. As you pointed out, there are still many 3VZ-E engines with over 200,000 miles that did not have any kind of major failure.
Old Mar 1, 2019 | 11:11 AM
Rpowell600's Avatar
Im returning the headers and sticking with stock. I appreciate everyone's input!
travisamorgan
Jul 11, 2014 06:14 PM
ColoradoToy91
3.4 Swaps
Mar 10, 2010 05:30 PM
Texas_Ace
Oct 25, 2008 04:37 PM
chimmike
Jan 6, 2007 02:40 PM
93yota88
Jun 22, 2006 11:51 PM
