3vze... died.
3vze... died.
I know this is my first post (long time lurker) and I realize everyone hates "first post SOS's" but seeing as how I think I just blew the motor I'm willing to accept (even expecting) some criticism on this one.
:h elp:
:hel p:
Usually I baby this truck just becuase the 3.slow is no drag racer. I short shift like an 80 yr old man. Today, was the one exception and the apocolypse might have happened under my hood.
I pulled out to pass some guy in a van doing 20mph. I ran 2nd up pretty good, shifted to third and thought "damn, this little truck is running much better than usual" So naturally I kept going and right as I went to back out of it and shift into 5th to cruise on home the motor sounds like it hit a limiter and died. Literally, for a split second it felt like a limiter, or a flat spot from over rev and died. Slowly just dropped all power to where it wouldn't move.
I let it sit for a few minutes, fired it up, have to give it some gas just to keep it idleing and definitely sounds like it's down at least a cylinder.
So Guru's... where should I start?
Thanks to all those who reply in advance. May you live long and prosper for it!
:h elp:
:hel p:Usually I baby this truck just becuase the 3.slow is no drag racer. I short shift like an 80 yr old man. Today, was the one exception and the apocolypse might have happened under my hood.
do you have headers or the stock manifolds with the cross over pipe? I wouldn't want that getting cherry red. And plugged cat could do it, engines do need to exhaust to function properly. Also, pull your plugs. What color are they? great info here, picked it up from another thread on YT: http://www.theultralightplace.com/sparkplugs.htm
Ok, after learning about the "paper clip" method of the CEL codes I got 4-2-5-2.
I'm assuming that is code(s) 42 and 52? Or maybe 4, 2, 5, 2?
I'm still running searches like a mad man but... any experience with this?
The code 52 will tell the computer 2 retard the ignition to 0. That would cause both your no power and your red hot exhaust manifold. The problem is most likely the pigtail to the knock sensor.... take us about 30 bucks at the dealer, but you have to tear the entire manifold off to get to it.
TNRabbit...
That's what I'm thinking as well. I first read about that after I found out what the codes were. (Thanks Bone Collector!)
We loosened the bolt on the side of the distributer and moved it slightly which allowed it to actually run/move on it's own power. It's still not right obviously but it at least allowed us to move it around the driveway easier.
This pigtail wire, is this something that can be purchased separately from the knock sensor? Or is it a package deal? I called my local autozone for the knock sensor and it's a special order part according to the guy behind the counter. Does that sensor go bad or jsut the wire usually? I'm still sifting through the endless info on the 3vze as to what is "problematic" and what isn't.
Thanks to all who replied btw!
