3vz afm adjustment question..
Old Aug 9, 2013 | 04:50 PM
Borg18's Avatar
I've read a few threads on adjusting the wheel in the afm and also referenced other write ups on other sites ..my question is, some people say turn counter clockwise for lean and i found a couple of pics that have arrows pointing clockwise for lean...which way is lean?
Old Aug 9, 2013 | 04:55 PM
a51young's Avatar
I turned mine counter clockwise and saw an increase in mpg, also advanced my timing to 15*, not sure if that did anything or not though haha. Also removed my efi fuse for a few minutes, not sure if that is necessary or not though either but I figured it wouldn't hurt anything
Old Aug 9, 2013 | 04:58 PM
Borg18's Avatar
This is a pic i found from one of the write ups
Old Aug 9, 2013 | 05:02 PM
a51young's Avatar
I think that might have been the one I did actually, mixed up the orientation of the teeth in my head.
This one here
http://www.customtacos.com/forum/showthread.php?t=56229
Old Aug 9, 2013 | 05:06 PM
Borg18's Avatar
Lol...awesome, the perfect person to clarify
..ok so it is counter clockwise then? How many clicks would be a saFe number?
Old Aug 9, 2013 | 05:34 PM
a51young's Avatar
haha, yeah it depends on how you count... I used that pic above when doing mine, 2 clicks lean. Some people do 3 or more. It probably depends on a few things in terms of safe, as that is fairly relative. 2 or 3 is probably safe, adjust idle and see how the next few tanks work.
Also put a mark at the stock location for reference.
should be moving the teeth clockwise right? probably use 2 flat heads or something to do it, that's what I did
Old Aug 9, 2013 | 09:31 PM
Inu's Avatar
Inu
Tighten spring leans it. Im at 14 clockwise/ lean but its not exactly stock or normal either.
Old Aug 10, 2013 | 02:57 AM
Borg18's Avatar
what kinda a mods do u have that allow u to lean it out so much? if u dont mind me asking
Old Aug 10, 2013 | 08:06 AM
Inu's Avatar
Inu
Cut off muffler, rebuilt engine, cams, and oversize injectors. Before the injectors it would lean out at hi rpm due to afm maxing out.
zytra
Jan 24, 2019 03:16 PM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
toyotasaurus
Sep 24, 2015 03:30 PM
