3 inch lift questions
Old Jan 26, 2007 | 09:45 AM
mathew69's Avatar
I just recently purchased a 3inch body lift for my 92 runner SR5 manual,, off Ebay with all the necessary parts and equiptment,, Im wondering if anyone has some tips and suggestions on the best way to do the install?? Iam working out of my household garage with a couple jacks .... thanks
Old Jan 26, 2007 | 10:00 AM
BC Rider's Avatar
http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
Mathew - you should also read the other information on the bodylifts at that site so that you know what you are getting into with the height of your lift.
Old Jan 26, 2007 | 10:12 AM
mathew69's Avatar
Thanks for the input
Old Jan 26, 2007 | 11:33 AM
bballchrism's Avatar
when your jackng up the body make dont do it all at once to it slowly and look for hoses and wires that go tight so nothing gets puled o or broken
Old Jan 26, 2007 | 01:08 PM
MudHippy's Avatar
Polyurethane Body Bushings. Last way longer than rubber. Downey Off-Road has 'em cheap.
Old Feb 1, 2007 | 08:14 AM
mathew69's Avatar
just wondering if any knows what kind of extentions are going to be needed??? thanks
Old Feb 1, 2007 | 08:21 AM
4Crawler's Avatar
You can see some of the typical things that need attention above 1" of lift:
- http://www.4crawler.com/4x4/ForSale/...o.shtml#Taller
Old Feb 1, 2007 | 10:08 AM
tacoma728's Avatar
don't let anyone hear you say bodylift, that's a no-no here.
BTW : I love bodylifts and would recommend them to anyone but there are quite a few people on here that refer to the ****lift as profane.
Great choice by the way.
Old Feb 1, 2007 | 11:25 AM
MudHippy's Avatar
$#@! them ignant *&%$head morons. I haven't heard ANYBODY, with any experience driving with one, say(TO MY FACE, LOOKIN' ME IN THE EYE!) any different than you. They can be a usefull device, don't go believing the bulldada you hear from these derilects on this site.
Old Feb 1, 2007 | 11:47 AM
faubrunner64's Avatar
ok i did a 3 inch bl also. it is very smooth but remove the bracket that mounts your 4 wheel drive shifter on the tub it is right behind the t-case if that bends it is a bitch to get back into proper shape
Old Feb 8, 2007 | 04:52 PM
mathew69's Avatar
Does anyone know with a 3 inch lift if any hoses and such will be stretched to tight or break??
Old Feb 8, 2007 | 05:03 PM
i have one no hoses but i had a ground wire that i had to move the gas tank hose need to be adgusted some of the house are tight and you might need to unbolt a bracket to give it some space nad just cut a longer hose later
Old Feb 8, 2007 | 07:13 PM
4Crawler's Avatar
As posted above, feel free to read over the following instructions and notes about installing taller body lifts:
- http://www.4crawler.com/4x4/ForSale/....shtml#Updates
Hard to give any specific details, as these tend to vary by year and model vehicle and even within a given year. For example, I had shifter issues on my '85 w/ 1" body lift and had a buddy install a 2" lift on his '85 and he had no issues at all. Nothing you'll run into is insurmountable, some hoses/wires might need some adjustment or relocation.
Old Feb 15, 2007 | 10:13 PM
mathew69's Avatar
I appreciate the feed back thanks alot guys
Old Feb 16, 2007 | 10:51 AM
tacoma728's Avatar
i love my bodylift and it helped out my approach and departure angles tremendously. I couldn't wheel without it.
Old Feb 16, 2007 | 10:57 AM
drew303's Avatar
I have a 2" body lift ..Hard brake lines in the motor bay were stretched broke rear ground on the motor off..
i found instructions worthless. just keep your eyes and ears open while you install each mount.
Old Feb 16, 2007 | 11:02 AM
tacoma728's Avatar
yeah, instructions might as well been toilet paper
Old Feb 18, 2007 | 08:20 PM
mathew69's Avatar
ive got a couple sets of intruciton. the one that came with the lift and a set of the net with pictures and stuff so hopefully they come in hand,, im just waiting til the cold weather to end here to i can get er done up!
88sasturbotoy
Jan 30, 2026 01:57 PM
coffey50
Jul 28, 2015 10:55 AM
Michael oaks
Jul 27, 2015 11:47 AM
Yotoder865
Jul 9, 2015 07:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
