3.0 V6 Cold Starts fine dies after warming up
Old Jun 17, 2010 | 06:05 PM
losmosis's Avatar
I have a 95 4Runner with a 3.0 V6. It starts fine cold and will run fine until it gets warmed up. After warm up 10-15 minutes it just dies and wont start again until it cools off a bit. However it is not running hot. Them temp guage doesn't work very well so I used a temp gun directly on the engine. It read close to the same temp as my 91 3.0 V6. So I know its not hot at 170deg. on the intake.
Acts like you just turned off the key.
Old Jun 18, 2010 | 09:48 AM
losmosis's Avatar
I need help here to guys. I have to get one of these yotas to run. they are both daily drivers.
Old Jun 21, 2010 | 03:21 AM
losmosis's Avatar
Come on guys someone knows the problem.... please help.
Old Jun 21, 2010 | 05:32 AM
Team420's Avatar
I would start with the coil.... those tend to show problems when hot....
Look for cracks, and white marks on it....then test it cold with the multimeter, then again when hot....
report you findings....
Old Jun 21, 2010 | 07:49 AM
thook's Avatar
Then, there's coolant temp sensor, air idle control valve, aiflow meter circuit, fuel pressure regulator......
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
Coil's a good place to start. After warm up? I'd also check the air idle valve and/or coolant sensor.
Old Jun 21, 2010 | 10:01 AM
losmosis's Avatar
The primary side of the coil is out of specs. I have one ordered so I'll let ya know if that is the problem.
Thanks.
Old Jun 21, 2010 | 10:05 AM
losmosis's Avatar
thook the link you just posted. http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
What is the index page? Can you post a link for it?
Old Jun 25, 2010 | 05:12 AM
thook's Avatar
What's the matter? Are you not able to access the page? IOW, I clicked on the link in your post, but it says link can't be found. But, when I click on the link I posted, it takes you right to the 3vze troubleshooting page.
Old Jun 25, 2010 | 08:40 AM
sb5walker's Avatar
http://personal.utulsa.edu/~nathan-b...fsm/index.html
http://www.ncttora.com/fsm/index.html
nvwiggins
13
Jun 16, 2016 03:05 PM
JHalcyonM
Sep 14, 2015 01:10 AM
sanctfy
Sep 13, 2015 06:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
