3.0 V6 91 pickup Clutch install help
Old Jan 29, 2012 | 10:52 AM
Cody91's Avatar
Angry 3.0 V6 91 pickup Clutch install help
So im doing the clutch on my 91 pick-up with the 3.0 and i would like to know if i have to REMOVE EXHAUST PIPE ( Remove the 3 nuts, exhaust pipe and gasket from the exhaust manifold) to get the tranny out As the FSM states.
But they are rusted on and striped i have sprayed them with PB for 2 days and i need to get it done to day. As for i have work in the morning. That is the only thing holding me up. if i don't have to remove it that would be nice.
Yes i have a tranny jack & Pilot Bearing Puller
Any help or tips would be nice. thank you
Gonna go back and give it a shot. will check back in few
Old Jan 29, 2012 | 11:16 AM
bone collector's Avatar
i just changed the clutch on my 94 v6 and i never had to touch the exhaust. there is plenty of room to get to all the tranny bolts to remove the tranny and change the clutch. good luck
Old Jan 29, 2012 | 11:44 AM
Cody91's Avatar
What about the 12. REMOVE FRONT DIFFERENTIAL SET BOLTS
(a) Remove the 3 bolts. (b) Support the front differential.
i dont rember doing that on the last on i did but that was a wile ago
Old Jan 29, 2012 | 02:45 PM
Nailit69's Avatar
Just changed mine too and never touched the exhaust or the front diff. Not sure if removing it would help anyway.
Old Jan 29, 2012 | 03:38 PM
^^ what he said. never touched the exhaust or the front diff. only had to remove the front driveshaft. dont take off more stuff then you need too.. keep it simple man good luck
Old Jan 29, 2012 | 05:50 PM
bmcghie's Avatar
Seconded (third?)... All I did was disconnect front ds from diff, rear ds from Tcase, Tcase crossmember from frame, ONE exhaust support from the bellhousing... then I unbolted the transmission + bellhousing and took it out. PS Taking off the front skid plate allows "easy" access to some starter bolts that also go through the bellhousing.
Good luck, don't forget to clean out the bellhousing and lube up the clutch fork pivot points before you put it back together!
Old Jan 30, 2012 | 04:37 PM
any luck?? get it done??
Old Jan 31, 2012 | 10:25 AM
Cody91's Avatar
Got the tranny out and new clutch in & the tranny back in But then I had to go to work still have a few bolts I need to tighten up than test drive. Thank you for all your fast input It helped a lot. Dang FSM wants you do do all kinds of useless stuff. Will let you all know how it turned out.
Old Jan 31, 2012 | 06:19 PM
Cody91's Avatar
Red face Thank you !
Well its all back in and it work's nice!
Got it done just in time for my road trip
Thank you all for your fast info it Saved a lot of time and stress
nvwiggins
13
Jun 16, 2016 03:05 PM
scott90
Oct 4, 2015 09:21 AM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
scheuvront1993
Sep 17, 2015 06:17 PM
seab1209
Sep 3, 2015 05:41 PM
