3.0 Engine Question?
Old Aug 6, 2007 | 02:50 PM
MudHippy's Avatar
Originally Posted by toyotajeep
EZ question time: A lack of low-end torque in a heavy vehicle is pretty typical of the 3.0 correct? There is no tach, but once the R's got up there it moved pretty good.
Correct. That's how mine is, even with a little tweaking(exhaust,ignition). The low end just lugs. Mine get's all kinds of power up above 3000 rpm.
I'm not sure what you mean by "miss". The idle never really steadies out, if that's what your noticing. It just kinda sways up&down between 750-850 rpm is what is specified in the FSM.
Check all your sparkplug wire connections. Sometimes one will back off the plug, makes the engine miss a little.
I had what I thought was a persistent non-curable miss type deal when I bought my truck. Turned out somebody had fiddled with the wrong screw when they tried to adjust the idle. Never could get it to idle smooth untill I got that other screw on the TB set right.
Old Aug 6, 2007 | 03:28 PM
thook's Avatar
Might that have been the throttle stop screw?
Old Aug 6, 2007 | 04:07 PM
MudHippy's Avatar
Sounds good to me. I understand what it does, just haven't quite known what to call it.
Old Aug 6, 2007 | 10:15 PM
thook's Avatar
Welp, that's what it's called. Now, doesn't your world feel in order again?
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
