Quote:
any fitment issues or rubbing with that size ? do you know what your backspacing is ? did you get about 2 inch gain with the bj spacers ? your tire converted to a 34 inch . break a cv yet wheeling ? nice looking 2nd gen ! ... well just looked at your previouse posts . awnsered most of my questions . looks like 3.75 bs , diff drop so cv are probly ok unless wheeling real hard . nice rig !Originally Posted by Dennis140
Finished up LC coil and bj spacer lift on 305/70/17
Quote:
This is EVERYTHING you need to lift a 2nd gen 4Runner.
1.5" BJ spacers
FJ80 Coils
Trailgear Brake Line
Skyjacker front shocks -SKYH7054
Skyjacker Rear Shocks - SKYH7024
4Crawler 4" Panhard
4Crawler 4" LSPV
Total cost:
~$250 including the 35 dollar rebate on the shocks and the 20% on sale.
Hope this helps... pictures will be posted when the lift is done.
Now this is for an approximate 2 inch lift? Got a lead on some fj coils for 75 bucks so I'm looking at this route. Are the skyjackers comparable to the nitrocharger ome shocks?Originally Posted by MaK92-4RnR
Figured I could add my .02 to this thread now.
1.5" BJ spacers
FJ80 Coils
4Crawler 4" Panhard
4Crawler 4" LSPV
Total cost:
Any leaning problems with one short coil and one long?
Disregard...due to impatience and my lead falling through ill just go with the ome coils...should I still fo with the 4 in panhard drop and 4 in lspv bracket?Originally Posted by MiikeyLawless
Now this is for an approximate 2 inch lift? Got a lead on some fj coils for 75 bucks so I'm looking at this route. Are the skyjackers comparable to the nitrocharger ome shocks?Any leaning problems with one short coil and one long?
Quote:
Ya you will need those no matter what spring/shock components you use to lift. I skipped on the panhard for a while and my axle was about 1/2" off center.Originally Posted by MiikeyLawless
Quote:
Yeah definately don't want that off center problem. So the 4" lspv and panhard drop should work without being too long or short? Kinda makes it pain having a weekend to do this. Which is why I'm just confirming befire I order wrong parts.Originally Posted by yotasavg
Quote:
Originally Posted by 1990-4runner
Any one running 5.29 gearing with 33-12.50 and alot of extra weight like bumpers and so. if so how do you like it?
Your revs will be too high in every gear and no highway use.
I put my gears in before I upped to 35's.
Lots of torque if it's trail only though.
Would like to appoligize in advance if this has been previously covered, I have searched and only found bits and pieces.
Gentlemen,
Going to purchase a set of rear FJ80 coils, new rear shocks, Panhard bar with 4" drop bracket kit (4crawler).
Am i forgetting anything?
Also for those who have done this already? What is the most difficult part? I feel like I may be getting in over my head but can't afford labor elsewhere.
Do I need BJ spacers or can I crank the torsion bars to compensate for this?
Gentlemen,
Quote:
Pros and cons of torsion bar cranking vs. ball joint spacers discussed below:Originally Posted by grenda
- http://www.4crawler.com/4x4/ForSale/...er.shtml#FAQ10
How-to links off of the same page:
- http://www.4crawler.com/4x4/ForSale/...nBarAdjustment
Is this a torsion bar? I'm pretty sure but doesn't look like are any drop down brackets. If it is what else will I need besides longer shocks and fj coils?
Quote:
Yep, panhard bar as noted above:Originally Posted by grenda
- http://www.4crawler.com/4x4/ForSale/...anhardDropBrkt
And a bracket to re-align that plus a bracket to raise the brake proportioning valve (LSPV):
- http://www.4crawler.com/4x4/ForSale/...l#LSPV_Bracket
Sorry bout that guys. Rookie mistake. Go get the lspv bracket plus a four inch drop down bracket for pan hard bar new shocks and coils? Then I should be good?
Sounds like a plan. A better plan would be to add balljoint spacers in the front rather than cranking the bars to the max. You'll lose your droop if you crank em, and your ride will suffer.
How involved is the installation? Reading off 4crawler looks like I have to do some cutting/trimming....which I'm ok with but feel I may be in over my head! Where offers the best price for the bj spacers? What about a decent rear shock? Not the cheapest,but something adequate being on a budget? Should I also remove away bars if this is my daily driver?
i love this thread every thing i needed was in it when i lift my 4runner i will let everyone here know i tip my hat to all of you
Hey guys, im not sure how old this thread is, but i saw it and found it slightly helpfull. Although i have some questions. I just recently bought my 1st 4runner. Ive been around them most of my life and decided it would make a great first car for my self. Now that i have it, i dont have a whole lot of money to spend on lift. I have a good friend that said he got his 3" suspension lift for his 1994 runner for around 150-200 bucks. if i can get one for around that price range thats less that 350 bucks, that would be what im going for. Any help?
