22re timing dead on 5btdc - some light backfiring
Old 08-02-2010, 08:38 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Hey guys! I did the headgasket all by my self in just two days I am proud of my self. I have no leaks or messes going on but I got number one up to tdc and lined the dizzy up facing one on the cap and she fired right up, and we set the timing with the light and got it dead on 5btdc, but I seem to have some popping and crackling when I let of the accelerator. Do I need to advance or retard the timing to get this out.
Old 08-02-2010, 09:14 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I just have one question.......how/why are you trying to set the timing if your TPS situation is in the air? Did you manage to get it adjusted right or something?
Old 08-02-2010, 10:26 AM
I changed the headgasket it on it and had to get it all back together in order to drive it. One thing I do know is when I tried testing the TPS the idle setting was within specs. I did the jumper thing, is not able to be timed then with the TPS suspected of being weird, even if the idle portion of the TPS checks out?
Old 08-04-2010, 08:43 PM
thook's Avatar
Would you mind rephrasing that last question? I'm not sure what you're asking.
Old 08-04-2010, 10:24 PM
874runnersr5's Avatar
yeah that doesn't make much sense, if you jump the terminals your idle is suppose to go down
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
ibayne
06-26-2015 06:30 AM
Quick Reply: 22re timing dead on 5btdc - some light backfiring
