22re sputtering only when accelerator is held steady.
Old Mar 19, 2009 | 02:05 PM
ThomasTedder's Avatar
I just had my motor rebuilt about 3,000 miles ago. When I did that, I replaced everything I could think of that would be in a tuneup (plugs, wires, cap, rotor, etc.). About 500 miles ago, I noticed a rare sputter here and there, only when cruising. Now it's way worse. It lurches constantly when driving down the road. It feels like the key is being turned off for a fraction of a second, then back on, over and over again. It idles perfect. It stops sputtering while accelerating, or when I let off the gas and coast. The plugs look perfect, but there is some black soot in the exhaust pipe. Please help.
Old Mar 20, 2009 | 07:57 AM
Anybody have any ideas?
Old Mar 20, 2009 | 08:03 AM
boontok's Avatar
Hi Thomas,
Does it sound like my problem:
4Runner w/ 22RE - temperature sensitive - low power, stuttering, surging, bad idle
Old Mar 20, 2009 | 08:14 AM
olharleyman's Avatar
cat 02 fuel filter?
Old Mar 20, 2009 | 01:39 PM
abecedarian's Avatar
stretched timing chain or broken guides / failing tensioner?
fuel injector with bad spray pattern?
Old Mar 20, 2009 | 01:51 PM
desertcox05's Avatar
i have same prob too. i noticed it last year in the summer but it seemed to have gone away over the winter. now that it is warmer i've noticed it again. It doesn't happen all the time. just like you decribed Thomas. just a real quick interuption in the ignition while driving (maintaining speed) but is fine while accelerating or completely off the gas.
Old Mar 20, 2009 | 02:02 PM
Has a new timing chain/tensioner (when I rebuilt the motor).
Old Mar 20, 2009 | 02:04 PM
Originally Posted by olharleyman
cat 02 fuel filter?
How would I check the 02 sensor?
I've never changed the fuel filter, guess it could be that (wouldn't it affect it under acceleration too?).
Old Mar 23, 2009 | 10:20 AM
ZUK's Avatar
ZUK
I bet you replaced the spark plug wires with a bright red or blue set of after-markets? I wonder if that's the prob.
Old Mar 23, 2009 | 10:24 AM
thook's Avatar
Fuel pump may be crapping out. Kinda sounds like it...a lot. Particularly since it's happening under load = losing fuel pressure/delivery.
Old Mar 23, 2009 | 04:22 PM
nope not under load. just at a steady speed. no probs under acceleration or decel.
Old Mar 23, 2009 | 04:36 PM
thook's Avatar
Well, it still could be the fuel pump. Last mine went south, it started out while cruising and then progressed to when accelerating.
Old Mar 23, 2009 | 06:34 PM
Kiroshu's Avatar
I had the same prob then i seafoamed it and it went away. TRY SEAFAOM IT WORKS!
Old Mar 28, 2009 | 02:34 PM
Tried the seafoam. The only thing it did was relieve me of ten dollars.
Decided to try changing the plug wires since they were under warranty. PROBLEM SOLVED!!!! It finally runs like it has a new motor (it does). The brand new Bosch "Ultra-Premium" wires went bad after only a few hundred miles. I think I'm about done with Bosch.
Old Mar 28, 2009 | 06:19 PM
i'm probably due to change mine too
Old Jul 23, 2009 | 04:38 PM
tysen86's Avatar
well desertcox did it fix yours. mine is doing it too!
Old Jan 31, 2015 | 01:11 PM
HRDC0R19's Avatar
I had a similar problem and just fixed it.
Back story
87 4Runner, 5speed, 22re. Completely rebuilt the engine, top, bottom, all accessories, clutch, everything I could think of. After +- 5K miles it started surging only while maintaining speed. Acceleration, deceleration, and idle were fine. I found out that I must have broken one side of the connector on the TPS sensor, because the metal retaining clip was missing and it was half off of the TPS sensor. I plugged it all the way in and secured it with bailing wire. Now it runs like it should (brand new)! Not that someone with these symptoms would have the same problem, but check, adjust, or replace your TPS.
Sidherish
Aug 2, 2015 01:42 PM
altydog
Jul 28, 2015 10:20 AM
jake_v
Jul 22, 2015 03:17 PM
shisha1999
Jul 13, 2015 11:09 PM
88runnergomas
Jul 9, 2015 01:12 PM
