22re performance motor
Old Aug 10, 2008 | 10:40 PM
annoyingrob's Avatar
I don't think an entire 2nd transmission would be worth it. You would be better off installing an overdrive unit onto the output of your transmission to further reduce gearing when needed.
This is essentially what you're doing if you install a 2nd transmission, and switching between 4th and 5th on it.
My brother used to have a separate overdrive unit on his Volvo, attached to the 4 speed manual transmission. You could re-wire it to operate in any gear, allowing you to split all 4 gears, giving you 8 effective gear ratios.
Old Aug 10, 2008 | 10:58 PM
muddpigg's Avatar
Well there you go, double overdrive and dual t-cases, thats what a total of 40 forward gears and 10 reverse. Have you considered dual engines, you know boats run'm. You boys got potential. Probably could do a whole post on it, perferribly somewhere beside this one. Thanks though.
Old Aug 14, 2008 | 05:55 PM
Most of those gears will be doubles though.
Old Aug 15, 2008 | 08:09 AM
abecedarian's Avatar
Originally Posted by muddpigg
Your absolutely right
http://rvingwithmarkpolk.blogspot.co...us-diesel.html
This may help, but if not I'm licked. Or may be wrong. If according to you, the hot ticket would be to run dual trannies (which is done but not popular) you could put two 5 speed trannies. One tranny turned backwards to step up rotation speeds. Run 5th gear in both and really get your rig moving. You could even do a write up and start a new trend. You may get the gearing set to run your rig with a Briggs and Stratton. Imagine the gas mileage you'd get with such a small engine.
What do you say, are you up to a challenge??
nope.
and I meant dual transfer cases, not transmissions.
and driving two identical manual transmissions in series, output to output shaft, would result in a 1:1 ratio at the far ends, if the same gear is chosen on both, not a step up.
Old Aug 15, 2008 | 08:12 AM
  #25
muddpigg's Avatar
I don't know what the I was thinking. I ordered the header gasket from DT instead of Summit. So for a week and a in half I've been waiting.
DT has a awesome product but crappy customer service, the sales repo outright lied to me. Hell customer service was the only thing pacestter had going for them.
Don't deal with Doug Thorley directly!!! That is why Summit is there for.
I feel better.
Old Aug 15, 2008 | 08:15 AM
  #26
muddpigg's Avatar
Originally Posted by abecedarian
nope.
My, My, My your wheels are turning but the drive is out of the rig!!!
Old Aug 15, 2008 | 08:16 AM
  #27
not sure what you meant there, but okay fine.
how's your quest for more power going?
Old Aug 15, 2008 | 08:21 AM
  #28
muddpigg's Avatar
Better when I get my gasket. Honestly can't wait to get to higher elevations. You been wheelin lately?
Old Aug 15, 2008 | 08:44 AM
  #29
ozziesironmanoffroad's Avatar
good luck with every thing man, sounds like a blast.
Old Aug 15, 2008 | 08:45 AM
  #30
nope. been in georgia until a few days ago. recuperating and adjusting to the time zones. may go hit the high desert of cali in a few weeks.
Old Aug 15, 2008 | 10:33 PM
  #31
muddpigg's Avatar
Got the exhuast gasket and no more leaks
I'm honestly impressed with the engine install. Still need to dial it in with a gas analyser. Diffenently an improvement over my previous engine, before the knock.
Of course it still a 4 cyl.
Sounds great too.
I'll post MPG's, later after done breaking the engine in.
Old Aug 16, 2008 | 01:25 AM
  #32
iselloil's Avatar
Mike built my engine,no problems.
Old Aug 19, 2008 | 02:01 AM
  #33
muddpigg's Avatar
So far I really like his work. Wheeled this past weekend. Engine performed flawlessly. I really like this set up, for both on road and off, I don't wheel by thottle so the low end torgue is sweet.
Though I could of done with out the body damage we encurred, good times.
Old Oct 1, 2008 | 05:07 PM
  #34
muddpigg's Avatar
Just some mpg's, these are with mud tires. I haven't swapped the A/T's on for a whole tank yet, been wheeling every chance I get. I've always gotten better mpg's with milder tread tires.
highway 19-20mpg
stop and go 14-15mpg
The stop and go is my back and forth to work about 3 miles eachway. So the 4RNR is just warmed up and out of open loop by the time I'm there.
I can tell a big difference in low end torque. Less skinny pedal which gives even greater traction control.
I really like the motor.
Old Sep 17, 2012 | 09:26 AM
  #35
derockus's Avatar
Bumping for an update on how your Sunwest long block has held up... i'm shopping for long blocks now and wanted to hear SOMETHING positive. Seems like most long block threads are complaints!
Old Sep 17, 2012 | 09:33 AM
  #36
iselloil's Avatar
Its doing great, No issues.I can call or email Mike at any time and he'll respond right away. They now do injector cleaning.Great shop.
Old Sep 17, 2012 | 09:41 AM
  #37
xylicon's Avatar
Just rolled over 20K on my Sunwest motor, no complaints here.
Old Sep 17, 2012 | 09:43 AM
  #38
derockus's Avatar
awesome, iselloil, 4 years is a good test period. glad to hear it's doing good!
muddpigg, how's yours been doing?
Old Sep 17, 2012 | 09:44 AM
  #39
derockus's Avatar
very cool, thanks for that. hard to find positive responses out there!
djpg2000
Nov 11, 2020 04:56 AM
cars-guy
Aug 16, 2020 06:59 AM
May 20, 2016 10:27 AM
Sep 4, 2015 09:27 AM
pyramid
Jul 30, 2015 10:05 AM
