22re Oil pump shim/pressure improvement?
Old Jan 23, 2007 | 02:56 PM
Barnstormer's Avatar
Is it possible to increase the oil pressure by shimming the relief valve? I have done this on other motors (VWs and such), and it looks like it might work for the 22re. There is an external hex headed bolt on the oil pump that contains a spring and check ball (I am pretty sure)
Would a stiffer spring or shim increase the oil pressure? I'd like a little more, as at 230k miles mine is a tad lower than I would like.
Any ideas?
Thanks!
Old Jan 23, 2007 | 04:00 PM
Flash319's Avatar
Get a new pump for Engbuldr.com for around $50 bucks. That is better then screwing with the heart of your engine. I am not sure that there is a pressure relief on these.
Old Jan 23, 2007 | 10:40 PM
tkm433's Avatar
Any ideas?
Thanks!
You might want to check this out
http://www.toyotacatalog.net/M1WebGe...2-1683F2407782
Old Jan 24, 2007 | 09:19 AM
Originally Posted by tkm433
AH HA!
That might be just the thing.
Thanks for the link!
B
Old Jan 24, 2007 | 09:20 AM
dcg9381's Avatar
Yes.. It works. If you have a look at the front of my motor, you can see I'm running one. The pump is a high volume/pressure pump provided by DOA:
http://lakebox.dnsalias.com/photos/1...nginefront.jpg
LC sells a shimmed by-pass also.
bigjstang
Jun 2, 2025 03:56 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
