22RE missing
Old Jul 19, 2007 | 05:06 PM
skife's Avatar
22RE missing
okay, timing is dead nuts on this thing, it idles great.
when i first start the truck up, it runs and drives like a top. it gets warm and then starts running like crap, if i give it any more than like 1/8th of a pedal of gas it wants to stall out. and just plain old runs like crap.
can you guys help me out here?
Old Jul 19, 2007 | 06:08 PM
Robrt32's Avatar
Mine sorta does the same thing.. As long as i drive real easy it will never miss a lick but if i try to run in a hurry at about half throttle it just smothers, I can let up off the gas and it will smooth out..When the motor is cold she will run like a bat of hell... I'm learning to just pet it and live with it.. Ive done all i know to do......
Old Jul 21, 2007 | 09:20 AM
Robrt32's Avatar
Bump, any ideas for me and Skife?
Old Jul 21, 2007 | 09:33 AM
thook's Avatar
Coolant temperature sensor...possibly.
I suppose no CEL codes? And have you all look at the troubleshooting guide in the FSM?
Old Jul 21, 2007 | 01:24 PM
Robrt32's Avatar
I have no codes
Old Jul 21, 2007 | 02:51 PM
Robrt32's Avatar
Ive done a lot or searching, reading, going outside and trying stuff this afternoon.. I traced it down to the TPS is my problem. After test driving with it unplugged it runs GREAT.. More power, fast acceleration .. I love it.. NOW, What is the down side of just leaving it unplugged?? Why should i buy another if runs great without it? I have slightly higher idle but not enough to worry about..
Old Jul 21, 2007 | 03:35 PM
HAVOC's Avatar
Have you tried adjusting it (thats if it is adjustable)?
Old Jul 21, 2007 | 04:17 PM
EvLTwiN's Avatar
even with a new topend, and ignition components i still get a little "miss" sound out of mine at idle. think my problem could be related?
Old Jul 21, 2007 | 04:23 PM
Robrt32's Avatar
unplug it and see if it runs any better..
Old Jul 21, 2007 | 05:17 PM
MMA_Alex's Avatar
unplugging it will give you worse gas mileage/power, but if it was badly adjusted in the first place it could minimize the symptoms. do a search for tps adjustment and you'll find info on how to get it properly dialed in at which point you need to recheck the timing, and it should be running much better.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
TDonkey
Jul 26, 2015 10:14 AM
