22re issues
Old Jan 23, 2011 | 06:32 PM
knobs's Avatar
22re issues
The other day, I was comin home, engine felt kinda jumpy, the it completly lost engine power and I pulled off the road and I popped the hood and the o2 sensor was glowing, and my runner wouldn't start again, I diagonsed the codes today and got 3, 6, and 10, then i turned it over to see if it would start, and it did, then I got codes 12 and 5 to add to the list, after it started runnin real crappy, I figured 5 would throw since it was glowing around the o3 sensor, but the other codes, im at a loss at what it might be! Any ideas?
Old Jan 24, 2011 | 07:04 AM
HawkStrong16's Avatar
Sounds to me like your catalytic converter is plugged up. That would cause the power lose and the glowing O2 sensor
I'm not sure about the codes though, If you don't have to worry about emissions try punching out your cat
Old Jan 24, 2011 | 08:24 AM
mountaingoat's Avatar
Here ya go: http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Old Jan 24, 2011 | 10:30 AM
knobs's Avatar
Thanks for that, I was thinkin it mightve been the the cat, but it was so sudden, and I just took emissions for the last time required for it, I just don't know why the knock sensor code would throw after everything else, as far as codes 3 6 and 10; I think the ignition coil is bad
Old Jan 24, 2011 | 11:38 AM
If you have an ohm meter, you can test your coil pretty easily. I don't remember the correct specs, but I bet a little googling would turn 'em up.
Old Jan 24, 2011 | 05:38 PM
knobs's Avatar
Well it started with codes still. But I wasn't up to running temp. If it was the coil, wouldn't it not run?
Old Jan 27, 2011 | 09:25 AM
knobs's Avatar
So I took the valve cover off to see if it was the timing chain, and nothings wrong there, any other ideas on what I could check?
Old Jan 27, 2011 | 02:37 PM
No, it'll run even with a bad coil...just not well.
However, from the codes you're getting I'd put my money on ECU or O2 sensor, or both. And especially if it's glowing around the O2.
I'd spend some time googling each code separately, for example "22re code 12" and see what people are coming up with for symptoms/fixes.
Old Jan 27, 2011 | 02:55 PM
knobs's Avatar
Ok. I just bought an o2 sensor yesterday and was gunna swap it in tonight, well see what happens, ill keep info posted, thanks for the help so far
Old Jan 29, 2011 | 01:27 PM
knobs's Avatar
So it turned out that it was the o2 sensor! All codes are clearand she's bangin like a champ again. Its odd somethin so simple would do that!
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
