22RE I revved my engine up and check engine light came on and now won't start
Old May 15, 2018 | 06:18 PM
Faithful's Avatar
Okay so here's the situation I have a 93 Toyota pickup with the 22RE engine I revved my motor up too pretty high RPMs and my engine light came on instantly, my engine died and will not start back it does crank just won't start any suggestions
Old May 15, 2018 | 06:38 PM
scope103's Avatar
Yeah. Don't rev it like that!
Gee, I wonder what it means when the "engine light" comes on? Could your truck be trying to tell you something?
Read the codes. Then we'll talk. http://web.archive.org/web/201410310...26diagnosi.pdf (The Special Service Tool (SST) is a paper clip.)
Old May 16, 2018 | 06:12 AM
skypilot's Avatar
Well did it end with a loud "BANG!"? Had that happen, dash went RED and gauges to zero. Found a rod outside the block and in the starter, and a hole in the pan. took a skyhook home. Could also be a broken crankshaft, spins but nothing happens.
That said the ecu has built in rev limiter at about 5 or 6k. So you may have broken a chain, and busted a valve.
Doesn't sound good.
Old May 16, 2018 | 06:24 PM
Faithful's Avatar
Doesn't sound good.
No there was no abnormal noise during it it just died Like I cut the key off
Old May 16, 2018 | 06:26 PM
Faithful's Avatar
​​​​​​now that I think about it the check engine light stays on before you start your engine so if it died the check engine light should come on because the key is still in the on position just not started I'll check for codes though and see May pull the valve cover off and check there too thanks for the reply
Old May 16, 2018 | 07:37 PM
akwheeler's Avatar
pull the distributor cap and crank the engine to see if the rotor spins
Old May 25, 2018 | 03:43 PM
Faithful's Avatar
I did the wires are chewed up that explains why there is no spark as a checked the spark plugs to I guess I'll need to replace the distributor also I noticed one of my coolant hoses are leaking near/under the exhaust do you know which hose that's called so I can order one
Old May 25, 2018 | 03:52 PM
akwheeler's Avatar
I sure don't, if you post a picture maybe someone will be able to help out. otherwise remove it and go to a parts store and see what they have that will work.
Old May 25, 2018 | 03:57 PM
Faithful's Avatar
Well thanks for helping
Old May 25, 2018 | 05:12 PM
RAD4Runner's Avatar
...will not start back it does crank just won't start any suggestions
AKWheeler is in Alaska, I'm in So Cal, Scope is in Nor Cal ? ... Sky Pilot in NY...
Put us in front of your engine compartment.
Let us know what you see, here, feel, smell, or not see, hear, feel, smell.
...I guess I'll need to replace the distributor...
STOP!
Don't start replacing parts unless you are absolutely sure they are bad AND replacing them will solve your problem.
... if you post a picture .
Yes. Pls see signature.
Labow
May 24, 2018 09:35 AM
