22RE Help!
22RE Help!
I have an 1988 P/U w/22RE and 240K miles on it. I have three codes getting thrown for it the Knock Sensor, TPS, and rich/lean. Before I tear into it I want to make sure nothing else is wrong. I've been having major power loss with it, it also will not idle if the truck is warm. It idles when it cold but the idle is fluctuating a lot. Along with the power loss it also sound like my dads old VW Thing. Its been cold up here, but there seems to have a lot smoke coming out of the tail pipe as well. I know it has a minor valve cover gasket leak, but would it cause a lot of smoke? The power loss and the sound came at the same time.Will either of those codes cause that problem?
I've replaced: Spark plugs, wires, cap and rotor about 300 miles ago.
couple things to check, first off how old is the O2 sensor. O2 sensors only last 60,000 miles in good conditions. if you are burning oil, your O2 sensor is bad with out a doubt. next is Exhaust leaks, which will also make an O2 sensor go bad quickly. I would then check for timing, i have found that mine got advanced some how which causes some issues. If all of those check out to be fine, clean both your Idle Air Control Valve and and the throttle body and inspect to see that the tps is with in specs.
I kinda figured the idle would be the TPS and I am pretty sure it is the original as well. Do you think the I should just replace the knock sensor as well. It is most likely the original too.
The coolant was a little low, but the oil looked fine. Drove it around the block and let it sit for 10-15 minutes and the temp gauge never went over a 1/4 of the way up. It was blowing hot air as well. Really hoping its not the head gasket, but it's still making the VW sound and still has no power at all. The smoke blowing out of it this morning wasn't white it was a little darker compared to the snow on the ground.
