22re fuel filter relocation
So I went to replace my fuel filter today so that all the oil and filters are changed with the first 1,000 miles on the new motor sounds like a easy and normal thing to do right? NOT!
What a pain in the as$ it is to get to in the truck, it was a breeze when the motor was on the hoist getting ready to drop it in, so after fighting to get at it from the under side for about a half hour I decided to see if I could mount it some where else besides the block.
After looking around for a few minutes and taking the fuel lines lengths into consideration, here is what I came up with( works for me may not be for everyone ) using the passengers side fender wall, the A/C hard line mount worked to mount the filter down, only one mount though but it is still very solid.
Yea I know it's not a Toyota filter but they said it would take 2 days to get one (You would think as popular as the 22re is they would have one or two on hand and not have to order one ) it's a Auto Zone replacement filter.
Thanks for the fuel filter relocation ideas!
I ended up drilling a hole about 3 inches toward the tire from where olharleyman mounted his. I just bolted a small 135* bracket and it fit well with my fuel line lengths.
That looks great I need to do this along with cutting a fuel pump hatch in the back. Half my repairs are done on road side so having to drop the tank or take apart the front end to change things is not ok and having giant hands makes it worse
This is exactly what I was thinking about doing. Anything that is battery, fuel, or brake related had better be 100% squared away and secure in my book. I wasn't sure about the line length so I reattached it in the factory location until I can cross more pressing issues off my list of WTH did the PO do that lol
Here's what I did with mine, very similar to what olharleyman did except I used some preexisting holes just above the access panel and below the AC line. Mine is mounted vertically as opposed to horizontally which I feel might give a bit more clearance between the intake manifold. It also didn't put any tension on the lines. You have options!
Tom
Tom
Thanks a lot for the ideas, guys! I haven't looked at mine that close, yet, because it sounded intimidating work - LOL. So a question... are the fuel lines leading to the filter flexible so it would be easy to relocate? OR are the lines rigid and requires careful bending?
TIA
TIA
Rubber lines but unless you had your 4Runner since birth who can say!!
I have one cable tied to the AC hose.
Another one Mounted in a old coil bracket to the inner fender.
If I recall the inline attaches to the side toward the front of the engine.
it just made for a smoother attachment to the fuel rail.
Ff relocation
TIA
TIA
Doing this as soon as the rain lets up a bit. I really can't believe how hidden this thing is, what a pain. No wonder they never get changed. Picked up a WIX since I thought $40 for a filter was crazy and everyone who didn't go with the toyota version, seems to go with the WIX one. Either way, will throw up a picture to add to this thread once mine is done.
pyramid
Jul 30, 2015 10:05 AM
Just watch reverse.
